Hi
I am working on a RN2483 project. On transmitting data, I noticed when I receive no channel available message, if I reset RN2483, I can bypass the duty cycle regulation and send data again.
Does it mean, the duty cycle limitation is implemented in the end-device only or it is rather a self-discipline?
ps. I understand it is stupid and selfish trying to engage or exceed maximum duty cycle. it is just out of curiosity
If your device is even close to the maximum duty cycle all day long, then itās way over the TTN Fair Access Policy. And while the duty cycle limitations would indeed be enforced by the device, if the Fair Access Policy is ever enforced, then that would be done on the network server, out of your control.
Also, the duty cycle regulations define the maximum during a deviceās peak usage, not an all day 24/7 maximum. If all of us would be using a duty cycle of 1% continuously, then even when transmissions magically somehow donāt collide and no downlinks are needed, the capacity would be as low as 100 devices per channel and SF.
So, for production devices stick to the limitations of the Fair Access Policy, or choose a different technology.
If one is close to the duty cycle maximum all day long, then LoRaWAN should not be your technology of choice, regardless the provider. Iād assume oneās need for that much data also requires (most of) that data to be delivered, which the license-free radio spectrum that LoRaWAN uses simply cannot guarantee. Especially not if many are sending that often. Simple mathematics.
TTNās Fair Access Policy of 30 seconds of uplinks per 24 hours is based on supporting 1,000 nodes per gateway, which seems really reasonable to me, even for commercial providers.
What is resetted is the ācounterā that RN2483 keeps of the previous transmissions done. For this reason is quite normal that a restart of RN2483 clear this ācounterā and start again acccumulating the āover the airā time for each channelā¦
