WB is White Board?
So it now is brown?
How you programming your nodes? Usb? I wanna use a JLink. For the Blinkexample it goes.
WB = Workbench
Greets
USB (DFU) with stm32duino bootloader.
Or use UART with USB to Serial on PA9/PA10.
Havenât used ST-LINK for sketch yet because I can use USB.
Note:
When using stm32duino and USB (DFU), upload sketch via serial or ST-Link will overwrite the stmduino bootloader again.
Are you using PlatformIO?
Not ST-Link. JLink (SEGGER).
Nope. I use Arduino-IDE.
Just curious, are you using the official ST STM32 tools for Arduino and âGeneric STMF103 seriesâ for the board (âSTM32 Cores by ST-Microelectronicsâ)?
In our comunity (little) the Master of Desaster want to use a full? IDE like Visual Studio.
But it stuck some times to create the HAL. We use MATRIX to configure the ground configuration for the BP.
I am NOT a developer! Most of the Things i doesen`t understand.
I want to use the existing codes/sketches and try to adapt them to my needs.
Nope. At my PC (LINUX) i create a own user for fiddeling with MCU at 32 bit. Like the BP or the Feather M0.
I use the code from @tomtor
Installing his code from Git.
The PlatformIO IDE is a plugin for the Atom and Visual Studio Code (vscode) code editors. Run on Windows, Linux and OSX. But probably more difficult if you are not a developer.
Here in the UK I purchased two of the '303 versions from BSFrance and they arrived just two days later! I cloned their github repo https://github.com/BSFrance/LoRaM3-D_templates and the code built with no errors using Atollic Studio - next step is to add some LoRaWAN codeâŚ
I see you have ST-Link connected. Are you using the Arduino stack? Have you tried to upload a sketch via USB (DFU) already?
No. I cloned the BSFrance github repo: https://github.com/BSFrance/BSFrance-stm32.git into my Arduino hardware folder and the boards show up OK, but I struggled with path length when trying to compile in Arduino on Windows and a failure to link in Arduino on a Mac - if anyone knows of a cure for
ââŚ
arm-none-eabi-gcc: fatal error: -fuse-linker-plugin, but liblto_plugin.so not found
âŚâ
Atollic is STM recommended and I think is a good STM32 IDE that is free to use for any STM32 MCU. It links easily with ST-Link, so I am partly happy as there is no Mac installer.
Seems like the arduino arm compiler canât find the shared lib.
This is a search on (linux) : gcc version 5.4.1 20160919 (gcc-arm-none-eabi-5_4-2016q3)
bingo@X200-1 ~/arm/arm-gcc/arm-gcc $ ls -lR | grep liblto_plugin.so
lrwxrwxrwx 1 bingo bingo 22 Sep 26 2016 liblto_plugin.so -> liblto_plugin.so.0.0.0
lrwxrwxrwx 1 bingo bingo 22 Sep 26 2016 liblto_plugin.so.0 -> liblto_plugin.so.0.0.0
-rwxr-xr-x 1 bingo bingo 73268 Sep 26 2016 liblto_plugin.so.0.0.0
/Bingo
I have not ran into path length issues on windows yet.(No Mac here.)
When/where do you have path issues?
Hi @bluejedi - I thought that my problems might be due to compile line length -
Detecting libraries usedâŚ
âC:\Arduino\hardware\BSFrance-stm32/stm32/tools/win/gcc/bin/arm-none-eabi-g++â -mcpu=cortex-m3 -DF_CPU=72000000L -mthumb -DSTM32GENERIC -DRAM_LENGTH=20472 -DFLASH_LENGTH=126976 -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -w -x c++ -E -CC -DSTM32F1 -DARDUINO=10805 -DARDUINO_LORAM3_D_F103CB -DARDUINO_ARCH_STM32 -DSTM32F103CB -DSTM32F1 -DHSE_VALUE=8000000 -DVECT_TAB_OFFSET=0x1000 -DMENU_USB_SERIAL -DMENU_SERIAL_AUTO=SerialUSB -DMENU_DEBUG_SWD â-IC:\Arduino\hardware\BSFrance-stm32\stm32\cores\arduino/stm32â â-IC:\Arduino\hardware\BSFrance-stm32\stm32\cores\arduino/usbâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/CMSISâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/STM32F1/CMSIS_Incâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/STM32F1/CMSIS_Srcâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/STM32F1/HAL_Incâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/STM32F1/HAL_Srcâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/STM32F1/stm32_chipâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\cores\arduinoâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\variants\LORAM3_D_F103CBâ âC:\Users\nicbk\AppData\Local\Temp\arduino_build_508715\sketch\BSFrance-303-LoRaSpreadRangeTest.ino.cppâ -o ânulâ
Generating function prototypesâŚ
âC:\Arduino\hardware\BSFrance-stm32/stm32/tools/win/gcc/bin/arm-none-eabi-g++â -mcpu=cortex-m3 -DF_CPU=72000000L -mthumb -DSTM32GENERIC -DRAM_LENGTH=20472 -DFLASH_LENGTH=126976 -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -w -x c++ -E -CC -DSTM32F1 -DARDUINO=10805 -DARDUINO_LORAM3_D_F103CB -DARDUINO_ARCH_STM32 -DSTM32F103CB -DSTM32F1 -DHSE_VALUE=8000000 -DVECT_TAB_OFFSET=0x1000 -DMENU_USB_SERIAL -DMENU_SERIAL_AUTO=SerialUSB -DMENU_DEBUG_SWD â-IC:\Arduino\hardware\BSFrance-stm32\stm32\cores\arduino/stm32â â-IC:\Arduino\hardware\BSFrance-stm32\stm32\cores\arduino/usbâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/CMSISâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/STM32F1/CMSIS_Incâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/STM32F1/CMSIS_Srcâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/STM32F1/HAL_Incâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/STM32F1/HAL_Srcâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\system/STM32F1/stm32_chipâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\cores\arduinoâ â-IC:\Arduino\hardware\BSFrance-stm32\stm32\variants\LORAM3_D_F103CBâ âC:\Users\nicbk\AppData\Local\Temp\arduino_build_508715\sketch\BSFrance-303-LoRaSpreadRangeTest.ino.cppâ -o âC:\Users\nicbk\AppData\Local\Temp\arduino_build_508715\preproc\ctags_target_for_gcc_minus_e.cppâ
arm-none-eabi-g++: error: CreateProcess: No such file or directory
I read this: https://github.com/arduino/Arduino/issues/6751
Hi @JTP,
0,13mA is not that bad, you will run over 1.5 years on a 2000mAh cell.
I assume your software is OK, but that either a voltage regulator is consuming current or you have floating input lines. Hard to say without a schematic of your designâŚ
I saw that itâs able to get something around 4uA which is something really useful. I use a 2600mAh cell, but I donât have the equipment to measure the sending time. I have 3 currents in my Lora end-device ( 1.- Sleep mode: 0.13mA. 2.- Wake-up: 6,05mA. 3.- Data sending: 23mA.). I have a circuit that measures the capacity percentage of the batteries cell in I2C, but I have some troubles in the I2C communication (Iâm not sure if itâs a software or hardware problem).
You can see my circuit in the picture bellow:
I appreciate all your help.
Best regards
@JTP This is likely more a STM32L0 question than that it is a Hope RFM95/98 power usage issue. This STM32L0 related article might help. Also the STM32 forum is probably a good source for more information.
Completely powering off the RFM9x could also be an option for minimizing battery usage.
Ah I just see @Charles already suggested this.
@tomtor Thanks for your wonderful post https://www.thethingsnetwork.org/labs/story/a-cheap-stm32-arduino-node
Unfortunately, the code doesnât compile for my setup ( https://github.com/stm32duino/Arduino_Core_STM32 ) with the bluepill board stm32f103 gives some function not defined error for stdout streams.
On the other hand the âofficialâ library from arduino library manager (1.5+arduino-2 from drop down menu) compiles, but interrupts are creating some problems. This is caused by disableIRQs function where it disables interrupts. if i disable it be commenting it out, i get upto the point of Starting, Packet Queued. I can see the packets in my TTN consoleâŚbut there is not event notified whether the packet was successful.
So i can not send any more data like sensor valuesâŚThis also applies to your library.
Kindly help, so that this cheap but capable board can really fly up to its potentialâŚ
thanks.
