I will go back and try ABP. I have applied the patch you linked, to my local library, but I still get no further than EV_JOINING. I added the following to radio.c
// called by hal to check if we got one IRQ
u1_t radio_has_irq (void) {
u1_t flags ;
if( (readReg(RegOpMode) & OPMODE_LORA) != 0) { // LORA modem
flags = readReg(LORARegIrqFlags);
if( flags & ( IRQ_LORA_TXDONE_MASK | IRQ_LORA_RXDONE_MASK | IRQ_LORA_RXTOUT_MASK ) )
return 1;
} else { // FSK modem
flags = readReg(FSKRegIrqFlags2);
if ( flags & ( IRQ_FSK2_PACKETSENT_MASK | IRQ_FSK2_PAYLOADREADY_MASK) )
return 1;
flags = readReg(FSKRegIrqFlags1);
if ( flags & IRQ_FSK1_TIMEOUT_MASK )
return 1;
return 0;
added declaration in oslmic.h
u1_t radio_has_irq (void);
changed this routine in hal.c
static void hal_io_check() {
uint8_t i;
for (i = 0; i < NUM_DIO; ++i) {
if (lmic_pins.dio[i] == LMIC_UNUSED_PIN)
// Check IRQ flags in radio module
if ( radio_has_irq() )
radio_irq_handler(0);
// We've soft checked IRQ reading Radio register no need to continue
// Setting this will exit us from for loop
i = NUM_DIO;
} else {
if (dio_states[i] != digitalRead(lmic_pins.dio[i])) {
dio_states[i] = !dio_states[i];
if (dio_states[i])
radio_irq_handler(i);
and commented out these two lines in hal_io_init
//ASSERT(lmic_pins.dio[0] != LMIC_UNUSED_PIN);
//ASSERT(lmic_pins.dio[1] != LMIC_UNUSED_PIN || lmic_pins.dio[2] != LMIC_UNUSED_PIN);
This all made sense tom me
