I have a gateway running with the iC880A Concentrator and the Basic Station.
It is running as well now.
I am currently in the process of creating the configuration file for the station.
How can I set the Tx Power? Cause this has a maximum value of 14dbm EIRP in Europe.
How can I set/synchronise the time? As you can see in the picture, the time does not match exactly by 2h. I have set the PPS to false, as I don’t have a GPS.
I believe the 14dbm limit is set allowing for standard 2 (actually 2.15) dbi ant giving EIRP of 16.1dBm. If you look at your 16 and further down in the .conf file the antenna_gain is set as 2 which then matches
Thanks for the answer, however I think EIRP = 14 dbm as max including antenna gain. And if I set the antenna_gain to 0 in the .conf file nothing changes in the TX power.
