Hi, everyone.
I have encountered a basic station protocol problem:
When I try to connect rpi gateway to ttn stack v3 using basic station protocol, the stack returns the error as shown:
basicstationlns:no_auth_provided (no auth provided for gateway id `{id}`)
The ttn-lw yaml is shown here:
# If Gateway Configuration Server enabled, defaults for "thethings.example.com":
gcs:
basic-station:
allow-unauthenticated: true
fallback-frequency-plan-id: ""
listen: ttnlorans.duckdns.org:1887
listen-tls: ttnlorans.duckdns.org:8887
use-traffic-tls-address: true
ws-ping-interval: 30s
Is there any other configuration to solve this problem?
Thx so much, everyone
This is the gateway logs:
2020-08-15 09:31:32.488 [SYS:INFO] Logging : stderr (maxsize=10000000, rotate=3)
2020-08-15 09:31:32.488 [SYS:INFO] Station Ver : 2.0.5(rpi/std) 2020-08-11 17:53:02
2020-08-15 09:31:32.488 [SYS:INFO] Package Ver : (null)
2020-08-15 09:31:32.488 [SYS:INFO] proto EUI : 0:b827:ebcb:c3cc (/sys/class/net/eth0/address)
2020-08-15 09:31:32.488 [SYS:INFO] prefix EUI : ::1 (builtin)
2020-08-15 09:31:32.488 [SYS:INFO] Station EUI : b827:ebff:fecb:c3cc
2020-08-15 09:31:32.488 [SYS:INFO] Station home: ./ (builtin)
2020-08-15 09:31:32.488 [SYS:INFO] Station temp: /var/tmp/ (builtin)
2020-08-15 09:31:32.488 [SYS:WARN] Station in NO-CUPS mode
2020-08-15 09:31:32.690 [TCE:INFO] Starting TC engine
2020-08-15 09:31:32.691 [any:INFO] ./tc.trust:
cert. version : 3
serial number : 0A:01:41:42:00:00:01:53:85:73:6A:0B:85:EC:A7:08
issuer name : O=Digital Signature Trust Co., CN=DST Root CA X3
subject name : C=US, O=Let’s Encrypt, CN=Let’s Encrypt Authority X3
issued on : 2016-03-17 16:40:46
expires on : 2021-03-17 16:40:46
signed using : RSA with SHA-256
RSA key size : 2048 bits
basic constraints : CA=true, max_pathlen=0
key usage : Digital Signature, Ke2020-08-15 09:31:32.691 [AIO:INFO] tc has no key+cert configured - running server auth only
2020-08-15 09:31:32.881 [TCE:INFO] Connecting to INFOS: wss://ttnlorans.duckdns.org:8887
2020-08-15 09:31:33.133 [TCE:INFO] Infos: b827:ebff:fecb:c3cc muxs-::0 wss://ttnlorans.duckdns.org:8887/traffic/eui-B827EBFFFECBC3CC
2020-08-15 09:31:33.133 [AIO:DEBU] [3] ws_close reason=1000
2020-08-15 09:31:33.133 [AIO:DEBU] Echoing close - reason=1000
2020-08-15 09:31:33.133 [AIO:ERRO] Recv failed: SSL - The peer notified us that the connection is going to be closed
2020-08-15 09:31:33.133 [AIO:DEBU] [3] WS connection shutdown…
2020-08-15 09:31:33.133 [any:INFO] ./tc.trust:
cert. version : 3
key usage : Digital Signature, Ke2020-08-15 09:31:33.133 [AIO:INFO] tc has no key+cert configured - running server auth only
2020-08-15 09:31:33.139 [TCE:VERB] Connecting to MUXS…
2020-08-15 09:31:33.316 [AIO:ERRO] [3] WS upgrade failed with HTTP status code: 401
2020-08-15 09:31:33.316 [AIO:DEBU] [3] WS connection shutdown…
2020-08-15 09:31:33.316 [TCE:VERB] Connection to MUXS closed in state 3
2020-08-15 09:31:33.316 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
Any information for this problem?
kersing
(Jac Kersing)
August 15, 2020, 5:44pm
4
A bit impatient? There won’t be a lot of people that know about this particular setup and over the weekend most will be off-line.
Thx so much. This issue has been solved. So, I will close this problem.
jasonreiss
(Jason Reiss)
August 16, 2020, 3:29am
6
Please share what your issue was so others may benefit.
It is ok. I am busy recently and will make the summarization in few days.
system
(system)
Closed
September 14, 2020, 9:28am
8
This topic was automatically closed after 30 days. New replies are no longer allowed.
