Has anyone else noticed that setting the GW_GPS environment variable to true doesn’t seem to do anything such as enable the PPS input.
I’m keen to get PPS up and running and a manual edit of the station.conf in the docker container to include “pps”: true in the radio config works but enabling the GPS through GW_GPS in the docker compose file or balena interface doesn’t - presumably as its not an environment variable passed through to basicstation nor does it select a different station.conf in the shell scripts.
Bug filed here: GPS PPS Not Working · Issue #42 · mpous/basicstation · GitHub Would be interested in feedback
