Backup TTN Stack v3 Devices
Hi everyone
I am using the things stack open source v3.12.3. Can anyone help on how to backup or export all the created devices within the application. I only see an option for importing devices but not for exporting them. I also see that there is a ttn-lw-migrate tool, is it possible to use it to export ttn v3 devices or is only used when migrating from v2 to v3.
Thank you
Use the CLI
I don’t know if I am missing something here but, when I try to use the CLI (ttn-lw-migrate) I get the error.
Capture
I don’t know if is the right CLI for exporting the devices. I can’t find a way on how to export these devices on v3.
From the error message I think you didn’t make the setup for cli access.
I did the setup please see below:
Screenshot (143)
I don’t know if there is anything I did wrong.
The migration tool is to get devices OUT of v2.
You have pointed the tool at a v3 instance …
Try the CLI tool
Thanks @descartes, can you please point me to where can I find the CLI command for exporting the devices, I only see commands for migration tool.
https://www.thethingsindustries.com/docs/reference/cli/end_devices/
or
http://descartes.co.uk/TTSv3CLI.html
thanks, I have successfully exported the devices.
