Today we started auto-migrating TTIGs from The Things Network V2 to The Things Stack Community Edition.
In order for your gateway to be picked up by the auto-migration tool, it needs to meet the following conditions:
- The gateway is registered on The Things Network V2
- The gateway was registered (on V2) by a user that signed into The Things Stack Community Edition (V3) with The Things ID at least once.
- The gateway is a TTIG (the EUI starts with
58A0CBFFFE8
) - The gateway is connected (online) to The Things Network V2
- The gateway ID (
eui-58a0cbfffe8...
) is not registered in The Things Stack Community Edition (V3) - The gateway EUI (
58A0CBFFFE8...
After the auto-migration tool migrates a gateway, you will be able to see the gateway in the Console.
- The ID of the gateway will be
eui-58a0cbfffe8...
You can not change the ID. If you have the claim authentication code (the WiFi password) of your gateway, you can delete the auto-migrated registration and follow the gateway claiming process to claim it again using a different ID. - The Name of the gateway will be “Auto-Migrated TTIG 58a0cbfffe8…”
You can change this. - The gateway has the organization
ttig-migration
as a collaborator
You can remove this.
NOTE: After auto-migration, it may take up to 24 hours for the gateway to connect to The Things Stack Community Edition (V3).
