Hi everyone, new user here.
I’m trying to set up a LoRa Node using a Raspberry Pi and a Dragino shield with LMiC library. I need to enable channels 64 to 71 using de AU915 band, which are supposed to be 500kHz each.
I’ve allready adapted the US915 part of the code as follows:
lorabase.h:
enum { US915_125kHz_UPFBASE = 915200000,
US915_125kHz_UPFSTEP = 200000,
US915_500kHz_UPFBASE = 915900000,
US915_500kHz_UPFSTEP = 1600000,
US915_500kHz_DNFBASE = 923300000,
US915_500kHz_DNFSTEP = 600000
enum { US915_FREQ_MIN = 915000000,
US915_FREQ_MAX = 928000000 };
lmic.c:
void LMIC_disableChannel (u1_t channel) {
if( channel < 72+MAX_XCHANNELS )
LMIC.channelMap[channel/16] &= ~(1<<(channel&0xF));
and of course i’ve set the CFG_us915 flag.
I’ve managed to disable certain channels using the LMIC_disableChannel() API, however, the ones remaing enabled don’t behave as I would’ve expected. When I disable every channel except for 64 to 71, I get the node to send in 8 different channels but with a BW of 125kHz and definitely not centered in the frequencies indicated in the LoRa specification: “8 channels numbered 64 to 71 utilizing LoRa 500 kHz BW at DR6 starting at 915.9 MHz and incrementing linearly by 1.6 MHz to 927.1 MHz” https://lora-alliance.org/sites/default/files/2018-04/lorawantm_regional_parameters_v1.1rb_-_final.pdf
I’m a little lost on what to do now. If anyone has managed to get something similar to work, I would very much appreciate the help.
Note: I’m working with an spectrum analyzer to see at which frequencies and Bw is the node sending.
Thanks in advance!
Florencia
