ATtiny85 + RFM95 Temperature Sensor
DSC_1239
This is a quick and dirty sketch of a temperature sensor running on a ATtiny 85.
The ATtiny internally 8Mhz oscilator devided by 8 is used.
Brown-out detection is set to 1.8V.
The node has a fixed datarate and channel frequency, and sends the temperature data every minute
goes to sleep in power down mode and wakes up by the watchdog timer.
I use the LoraWan and AES encryption from Gerben den Hartog
and Arduino tinySPI Library http://github.com/JChristensen/tinySPI
#include <tinySPI.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
#define DIO0 PB3
#define NSS  PB0
#define TEMP A2
// the value of resistor
#define SERIESRESISTOR 10000
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// temp. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3950
// how many samples to take and average
#define NUMSAMPLES 5
int samples[NUMSAMPLES];
unsigned int Frame_Counter_Tx = 0x0000;
static const unsigned char PROGMEM S_Table[16][16] = {
  {0x63,0x7C,0x77,0x7B,0xF2,0x6B,0x6F,0xC5,0x30,0x01,0x67,0x2B,0xFE,0xD7,0xAB,0x76},
  {0xCA,0x82,0xC9,0x7D,0xFA,0x59,0x47,0xF0,0xAD,0xD4,0xA2,0xAF,0x9C,0xA4,0x72,0xC0},
  {0xB7,0xFD,0x93,0x26,0x36,0x3F,0xF7,0xCC,0x34,0xA5,0xE5,0xF1,0x71,0xD8,0x31,0x15},
  {0x04,0xC7,0x23,0xC3,0x18,0x96,0x05,0x9A,0x07,0x12,0x80,0xE2,0xEB,0x27,0xB2,0x75},
  {0x09,0x83,0x2C,0x1A,0x1B,0x6E,0x5A,0xA0,0x52,0x3B,0xD6,0xB3,0x29,0xE3,0x2F,0x84},
  {0x53,0xD1,0x00,0xED,0x20,0xFC,0xB1,0x5B,0x6A,0xCB,0xBE,0x39,0x4A,0x4C,0x58,0xCF},
  {0xD0,0xEF,0xAA,0xFB,0x43,0x4D,0x33,0x85,0x45,0xF9,0x02,0x7F,0x50,0x3C,0x9F,0xA8},
  {0x51,0xA3,0x40,0x8F,0x92,0x9D,0x38,0xF5,0xBC,0xB6,0xDA,0x21,0x10,0xFF,0xF3,0xD2},
  {0xCD,0x0C,0x13,0xEC,0x5F,0x97,0x44,0x17,0xC4,0xA7,0x7E,0x3D,0x64,0x5D,0x19,0x73},
  {0x60,0x81,0x4F,0xDC,0x22,0x2A,0x90,0x88,0x46,0xEE,0xB8,0x14,0xDE,0x5E,0x0B,0xDB},
  {0xE0,0x32,0x3A,0x0A,0x49,0x06,0x24,0x5C,0xC2,0xD3,0xAC,0x62,0x91,0x95,0xE4,0x79},
  {0xE7,0xC8,0x37,0x6D,0x8D,0xD5,0x4E,0xA9,0x6C,0x56,0xF4,0xEA,0x65,0x7A,0xAE,0x08},
  {0xBA,0x78,0x25,0x2E,0x1C,0xA6,0xB4,0xC6,0xE8,0xDD,0x74,0x1F,0x4B,0xBD,0x8B,0x8A},
  {0x70,0x3E,0xB5,0x66,0x48,0x03,0xF6,0x0E,0x61,0x35,0x57,0xB9,0x86,0xC1,0x1D,0x9E},
  {0xE1,0xF8,0x98,0x11,0x69,0xD9,0x8E,0x94,0x9B,0x1E,0x87,0xE9,0xCE,0x55,0x28,0xDF},
  {0x8C,0xA1,0x89,0x0D,0xBF,0xE6,0x42,0x68,0x41,0x99,0x2D,0x0F,0xB0,0x54,0xBB,0x16}
unsigned char NwkSkey[16] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
unsigned char AppSkey[16] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
unsigned char DevAddr[4] = { 0x00, 0x00, 0x00, 0x00 };
// sleep cycles
volatile int sleep_count = 0;
const int sleep_total = 8; // 8*8s 64s sleep time
void setup() {
  SPI.setDataMode(SPI_MODE0);
  SPI.begin();
  pinMode(NSS, OUTPUT);
  pinMode(DIO0, INPUT);
  digitalWrite(NSS, HIGH);
  // Turn on the watch dog timer
  watchdogOn();
  //Initialize RFM module
  RFM_Init();
void loop() {
  goToSleep();
  if (sleep_count >= sleep_total) {
    uint16_t temp;
	  uint8_t Data[2];
	  uint8_t Data_Length = 0x02;
    temp = readThermistor() * 100;
    Data[0] = (temp >> 8) & 0xff;
    Data[1] = temp & 0xff;
    LORA_Send_Data(Data, Data_Length, Frame_Counter_Tx);
    Frame_Counter_Tx++;
    // reset sleep count
    sleep_count = 0;
* Description : Function contstructs a LoRaWAN package and sends it
* Arguments   : *Data pointer to the array of data that will be transmitted
*               Data_Length nuber of bytes to be transmitted
*               Frame_Counter_Up  Frame counter of upstream frames
void LORA_Send_Data(unsigned char *Data, unsigned char Data_Length, unsigned int Frame_Counter_Tx)
  //Define variables
  unsigned char i;
  //Direction of frame is up
  unsigned char Direction = 0x00;
  unsigned char RFM_Data[64];
  unsigned char RFM_Package_Length;
  unsigned char MIC[4];
  //Unconfirmed data up
  unsigned char Mac_Header = 0x40;
  unsigned char Frame_Control = 0x00;
  unsigned char Frame_Port = 0x01;
  //Encrypt the data
  Encrypt_Payload(Data, Data_Length, Frame_Counter_Tx, Direction);
  //Build the Radio Package
  RFM_Data[0] = Mac_Header;
  RFM_Data[1] = DevAddr[3];
  RFM_Data[2] = DevAddr[2];
  RFM_Data[3] = DevAddr[1];
  RFM_Data[4] = DevAddr[0];
  RFM_Data[5] = Frame_Control;
  RFM_Data[6] = (Frame_Counter_Tx & 0x00FF);
  RFM_Data[7] = ((Frame_Counter_Tx >> 8) & 0x00FF);
  RFM_Data[8] = Frame_Port;
  //Set Current package length
  RFM_Package_Length = 9;
  //Load Data
  for(i = 0; i < Data_Length; i++)
    RFM_Data[RFM_Package_Length + i] = Data[i];
  //Add data Lenth to package length
  RFM_Package_Length = RFM_Package_Length + Data_Length;
  //Calculate MIC
  Calculate_MIC(RFM_Data, MIC, RFM_Package_Length, Frame_Counter_Tx, Direction);
  //Load MIC in package
  for(i = 0; i < 4; i++)
    RFM_Data[i + RFM_Package_Length] = MIC[i];
  //Add MIC length to RFM package length
  RFM_Package_Length = RFM_Package_Length + 4;
  //Send Package
  RFM_Send_Package(RFM_Data, RFM_Package_Length);
* Description : Funtion that writes a register from the RFM
* Arguments   : RFM_Address Address of register to be written
*         RFM_Data    Data to be written
void RFM_Write(unsigned char RFM_Address, unsigned char RFM_Data)
  //Set NSS pin Low to start communication
  digitalWrite(NSS,LOW);
  //Send Addres with MSB 1 to make it a writ command
  SPI.transfer(RFM_Address | 0x80);
  //Send Data
  SPI.transfer(RFM_Data);
  //Set NSS pin High to end communication
  digitalWrite(NSS,HIGH);
* Description: Function used to initialize the RFM module on startup
void RFM_Init()
  //Switch RFM to sleep
  RFM_Write(0x01,0x00);
  //Set RFM in LoRa mode
  RFM_Write(0x01,0x80);
  //Set RFM in Standby mode wait on mode ready
  RFM_Write(0x01,0x81);
  while (digitalRead(DIO5) == LOW)
  delay(10);
  //Set carrair frequency
  // 868.100 MHz / 61.035 Hz = 14222987 = 0xD9068B
  RFM_Write(0x06,0xD9);
  RFM_Write(0x07,0x06);
  RFM_Write(0x08,0x8B);
  //PA pin (maximal power)
  RFM_Write(0x09,0xFF);
  //BW = 125 kHz, Coding rate 4/5, Explicit header mode
  RFM_Write(0x1D,0x72);
  //Spreading factor 7, PayloadCRC On
  RFM_Write(0x1E,0xB4);
  //Rx Timeout set to 37 symbols
  RFM_Write(0x1F,0x25);
  //Preamble length set to 8 symbols
  //0x0008 + 4 = 12
  RFM_Write(0x20,0x00);
  RFM_Write(0x21,0x08);
  //Low datarate optimization off AGC auto on
  RFM_Write(0x26,0x0C);
  //Set LoRa sync word
  RFM_Write(0x39,0x34);
  //Set IQ to normal values
  RFM_Write(0x33,0x27);
  RFM_Write(0x3B,0x1D);
  //Set FIFO pointers
  //TX base adress
  RFM_Write(0x0E,0x80);
  //Rx base adress
  RFM_Write(0x0F,0x00);
* Description : Function for sending a package with the RFM
* Arguments   : *RFM_Tx_Package Pointer to arry with data to be send
*               Package_Length  Length of the package to send
void RFM_Send_Package(unsigned char *RFM_Tx_Package, unsigned char Package_Length)
  unsigned char i;
  unsigned char RFM_Tx_Location = 0x00;
  delay(10);
  //Switch DIO0 to TxDone
  RFM_Write(0x40,0x40);
  //Set carrier frequency
  //SF7 BW 125 kHz
  RFM_Write(0x1E,0x74); //SF7 CRC On
  RFM_Write(0x1D,0x72); //125 kHz 4/5 coding rate explicit header mode
  RFM_Write(0x26,0x04); //Low datarate optimization off AGC auto on
  //Set payload length to the right length
  RFM_Write(0x22,Package_Length);
  //Get location of Tx part of FiFo
  //RFM_Tx_Location = RFM_Read(0x0E);
  //Set SPI pointer to start of Tx part in FiFo
  //RFM_Write(0x0D,RFM_Tx_Location);
  RFM_Write(0x0D,0x80); // hardcoded fifo location according RFM95 specs
  //Write Payload to FiFo
  for (i = 0;i < Package_Length; i++)
    RFM_Write(0x00,*RFM_Tx_Package);
    RFM_Tx_Package++;
  //Switch RFM to Tx
  RFM_Write(0x01,0x83);
  //Wait for TxDone
  while(digitalRead(DIO0) == LOW)
void Encrypt_Payload(unsigned char *Data, unsigned char Data_Length, unsigned int Frame_Counter, unsigned char Direction)
  unsigned char i = 0x00;
  unsigned char j;
  unsigned char Number_of_Blocks = 0x00;
  unsigned char Incomplete_Block_Size = 0x00;
  unsigned char Block_A[16];
  //Calculate number of blocks
  Number_of_Blocks = Data_Length / 16;
  Incomplete_Block_Size = Data_Length % 16;
  if(Incomplete_Block_Size != 0)
    Number_of_Blocks++;
  for(i = 1; i <= Number_of_Blocks; i++)
    Block_A[0] = 0x01;
    Block_A[1] = 0x00;
    Block_A[2] = 0x00;
    Block_A[3] = 0x00;
    Block_A[4] = 0x00;
    Block_A[5] = Direction;
    Block_A[6] = DevAddr[3];
    Block_A[7] = DevAddr[2];
    Block_A[8] = DevAddr[1];
    Block_A[9] = DevAddr[0];
    Block_A[10] = (Frame_Counter & 0x00FF);
    Block_A[11] = ((Frame_Counter >> 8) & 0x00FF);
    Block_A[12] = 0x00; //Frame counter upper Bytes
    Block_A[13] = 0x00;
    Block_A[14] = 0x00;
    Block_A[15] = i;
    //Calculate S
    AES_Encrypt(Block_A,AppSkey); //original
    //Check for last block
    if(i != Number_of_Blocks)
      for(j = 0; j < 16; j++)
        *Data = *Data ^ Block_A[j];
        Data++;
    else
      if(Incomplete_Block_Size == 0)
        Incomplete_Block_Size = 16;
      for(j = 0; j < Incomplete_Block_Size; j++)
        Data++;
void Calculate_MIC(unsigned char *Data, unsigned char *Final_MIC, unsigned char Data_Length, unsigned int Frame_Counter, unsigned char Direction)
  unsigned char i;
  unsigned char Block_B[16];
  unsigned char Key_K1[16] = {
  unsigned char Key_K2[16] = {
  //unsigned char Data_Copy[16];
  unsigned char Old_Data[16] = {
  unsigned char New_Data[16] = {
  unsigned char Block_Counter = 0x01;
  //Create Block_B
  Block_B[0] = 0x49;
  Block_B[1] = 0x00;
  Block_B[2] = 0x00;
  Block_B[3] = 0x00;
  Block_B[4] = 0x00;
  Block_B[5] = Direction;
  Block_B[6] = DevAddr[3];
  Block_B[7] = DevAddr[2];
  Block_B[8] = DevAddr[1];
  Block_B[9] = DevAddr[0];
  Block_B[10] = (Frame_Counter & 0x00FF);
  Block_B[11] = ((Frame_Counter >> 8) & 0x00FF);
  Block_B[12] = 0x00; //Frame counter upper bytes
  Block_B[13] = 0x00;
  Block_B[14] = 0x00;
  Block_B[15] = Data_Length;
  //Calculate number of Blocks and blocksize of last block
    Number_of_Blocks++;
  Generate_Keys(Key_K1, Key_K2);
  //Preform Calculation on Block B0
  //Preform AES encryption
  AES_Encrypt(Block_B,NwkSkey);
  //Copy Block_B to Old_Data
  for(i = 0; i < 16; i++)
    Old_Data[i] = Block_B[i];
  //Preform full calculating until n-1 messsage blocks
  while(Block_Counter < Number_of_Blocks)
    //Copy data into array
      New_Data[i] = *Data;
      Data++;
    //Preform XOR with old data
    XOR(New_Data,Old_Data);
    AES_Encrypt(New_Data,NwkSkey);
    //Copy New_Data to Old_Data
      Old_Data[i] = New_Data[i];
    //Raise Block counter
    Block_Counter++;
  //Perform calculation on last block
  //Check if Datalength is a multiple of 16
    //Copy last data into array
      Data++;
    //Preform XOR with Key 1
    XOR(New_Data,Key_K1);
    //Preform last AES routine
    // read NwkSkey from PROGMEM
  else
    //Copy the remaining data and fill the rest
      if(i < Incomplete_Block_Size)
        Data++;
      if(i == Incomplete_Block_Size)
        New_Data[i] = 0x80;
      if(i > Incomplete_Block_Size)
        New_Data[i] = 0x00;
    //Preform XOR with Key 2
    XOR(New_Data,Key_K2);
    //Preform XOR with Old data
  Final_MIC[0] = New_Data[0];
  Final_MIC[1] = New_Data[1];
  Final_MIC[2] = New_Data[2];
  Final_MIC[3] = New_Data[3];
void Generate_Keys(unsigned char *K1, unsigned char *K2)
  unsigned char i;
  unsigned char MSB_Key;
  //Encrypt the zeros in K1 with the NwkSkey
  AES_Encrypt(K1,NwkSkey);
  //Create K1
  //Check if MSB is 1
  if((K1[0] & 0x80) == 0x80)
    MSB_Key = 1;
  else
    MSB_Key = 0;
  //Shift K1 one bit left
  Shift_Left(K1);
  //if MSB was 1
  if(MSB_Key == 1)
    K1[15] = K1[15] ^ 0x87;
  //Copy K1 to K2
  for( i = 0; i < 16; i++)
    K2[i] = K1[i];
  //Check if MSB is 1
  if((K2[0] & 0x80) == 0x80)
    MSB_Key = 1;
  else
    MSB_Key = 0;
  //Shift K2 one bit left
  Shift_Left(K2);
  //Check if MSB was 1
  if(MSB_Key == 1)
    K2[15] = K2[15] ^ 0x87;
void Shift_Left(unsigned char *Data)
  unsigned char i;
  unsigned char Overflow = 0;
  //unsigned char High_Byte, Low_Byte;
    //Check for overflow on next byte except for the last byte
    if(i < 15)
      //Check if upper bit is one
      if((Data[i+1] & 0x80) == 0x80)
        Overflow = 1;
      else
        Overflow = 0;
    else
      Overflow = 0;
    //Shift one left
    Data[i] = (Data[i] << 1) + Overflow;
void XOR(unsigned char *New_Data,unsigned char *Old_Data)
  unsigned char i;
    New_Data[i] = New_Data[i] ^ Old_Data[i];
* Title         : AES_Encrypt
* Description  :
void AES_Encrypt(unsigned char *Data, unsigned char *Key)
  unsigned char Row, Column, Round = 0;
  unsigned char Round_Key[16];
    unsigned char State[4][4];
  //  Copy input to State arry
  for( Column = 0; Column < 4; Column++ )
    for( Row = 0; Row < 4; Row++ )
      State[Row][Column] = Data[Row + (Column << 2)];
  //  Copy key to round key
  memcpy( &Round_Key[0], &Key[0], 16 );
  //  Add round key
  AES_Add_Round_Key( Round_Key, State );
  //  Preform 9 full rounds with mixed collums
  for( Round = 1 ; Round < 10 ; Round++ )
    //  Perform Byte substitution with S table
    for( Column = 0 ; Column < 4 ; Column++ )
      for( Row = 0 ; Row < 4 ; Row++ )
        State[Row][Column] = AES_Sub_Byte( State[Row][Column] );
    //  Perform Row Shift
    AES_Shift_Rows(State);
    //  Mix Collums
    AES_Mix_Collums(State);
    //  Calculate new round key
    AES_Calculate_Round_Key(Round, Round_Key);
        //  Add the round key to the Round_key
    AES_Add_Round_Key(Round_Key, State);
  //  Perform Byte substitution with S table whitout mix collums
      State[Row][Column] = AES_Sub_Byte(State[Row][Column]);
  //  Shift rows
  AES_Calculate_Round_Key( Round, Round_Key );
    //  Add round key
  //  Copy the State into the data array
      Data[Row + (Column << 2)] = State[Row][Column];
} // AES_Encrypt
* Title         : AES_Add_Round_Key
* Description :
void AES_Add_Round_Key(unsigned char *Round_Key, unsigned char (*State)[4])
  unsigned char Row, Collum;
  for(Collum = 0; Collum < 4; Collum++)
    for(Row = 0; Row < 4; Row++)
      State[Row][Collum] ^= Round_Key[Row + (Collum << 2)];
} // AES_Add_Round_Key
* Title         : AES_Sub_Byte
* Description :
unsigned char AES_Sub_Byte(unsigned char Byte)
//  unsigned char S_Row,S_Collum;
//  unsigned char S_Byte;
//  S_Row    = ((Byte >> 4) & 0x0F);
//  S_Collum = ((Byte >> 0) & 0x0F);
//  S_Byte   = S_Table [S_Row][S_Collum];
  //return S_Table [ ((Byte >> 4) & 0x0F) ] [ ((Byte >> 0) & 0x0F) ]; // original
  return pgm_read_byte(&(S_Table [((Byte >> 4) & 0x0F)] [((Byte >> 0) & 0x0F)]));
} //    AES_Sub_Byte
* Title         : AES_Shift_Rows
* Description :
void AES_Shift_Rows(unsigned char (*State)[4])
  unsigned char Buffer;
  //Store firt byte in buffer
  Buffer      = State[1][0];
  //Shift all bytes
  State[1][0] = State[1][1];
  State[1][1] = State[1][2];
  State[1][2] = State[1][3];
  State[1][3] = Buffer;
  Buffer      = State[2][0];
  State[2][0] = State[2][2];
  State[2][2] = Buffer;
  Buffer      = State[2][1];
  State[2][1] = State[2][3];
  State[2][3] = Buffer;
  Buffer      = State[3][3];
  State[3][3] = State[3][2];
  State[3][2] = State[3][1];
  State[3][1] = State[3][0];
  State[3][0] = Buffer;
}   //  AES_Shift_Rows
* Title         : AES_Mix_Collums
* Description :
void AES_Mix_Collums(unsigned char (*State)[4])
  unsigned char Row,Collum;
  unsigned char a[4], b[4];
      a[Row] =  State[Row][Collum];
      b[Row] = (State[Row][Collum] << 1);
      if((State[Row][Collum] & 0x80) == 0x80)
        b[Row] ^= 0x1B;
    State[0][Collum] = b[0] ^ a[1] ^ b[1] ^ a[2] ^ a[3];
    State[1][Collum] = a[0] ^ b[1] ^ a[2] ^ b[2] ^ a[3];
    State[2][Collum] = a[0] ^ a[1] ^ b[2] ^ a[3] ^ b[3];
    State[3][Collum] = a[0] ^ b[0] ^ a[1] ^ a[2] ^ b[3];
}   //  AES_Mix_Collums
* Title         : AES_Calculate_Round_Key
* Description :
void AES_Calculate_Round_Key(unsigned char Round, unsigned char *Round_Key)
  unsigned char i, j, b, Rcon;
  unsigned char Temp[4];
    //Calculate Rcon
  Rcon = 0x01;
  while(Round != 1)
    b = Rcon & 0x80;
    Rcon = Rcon << 1;
    if(b == 0x80)
      Rcon ^= 0x1b;
    Round--;
  //  Calculate first Temp
  //  Copy laste byte from previous key and subsitute the byte, but shift the array contents around by 1.
    Temp[0] = AES_Sub_Byte( Round_Key[12 + 1] );
    Temp[1] = AES_Sub_Byte( Round_Key[12 + 2] );
    Temp[2] = AES_Sub_Byte( Round_Key[12 + 3] );
    Temp[3] = AES_Sub_Byte( Round_Key[12 + 0] );
  //  XOR with Rcon
  Temp[0] ^= Rcon;
  //  Calculate new key
    for(j = 0; j < 4; j++)
      Round_Key[j + (i << 2)]  ^= Temp[j];
      Temp[j]                   = Round_Key[j + (i << 2)];
}   //  AES_Calculate_Round_Key
float readThermistor() {
	uint8_t i;
  float average;
	float temp;
	// take N samples in a row, with a slight delay
	for (i=0; i< NUMSAMPLES; i++) {
	  samples[i] = analogRead(TEMP);
	  delay(10);
	// average all the samples out
	average = 0;
	  average += samples[i];
	average /= NUMSAMPLES;
	// convert the value to resistance
	average = 1023 / average - 1;
	average = SERIESRESISTOR / average;
	temp = average / THERMISTORNOMINAL;
	temp = log(temp);
	temp /= BCOEFFICIENT;
	temp += 1.0 / (TEMPERATURENOMINAL + 273.15);
	temp = 1.0 / temp;
	temp -= 273.15;
	return temp;
void watchdogOn() {
  // clear various "reset" flags
  MCUSR = 0;
  // allow changes, disable reset
  WDTCR = (1 << WDCE) | (1 << WDE);
  // set interrupt mode and an interval
  WDTCR = (1 << WDIE) | (1 << WDP3) | (1 << WDP0); // set WDIE, and 8 seconds delay
  wdt_reset();  // pat the dog
void goToSleep() {
  set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Set sleep mode.
  noInterrupts (); // timed sequence follows
  sleep_enable();
  interrupts (); // guarantees next instruction executed
  sleep_cpu(); // Enter sleep mode.
  // After waking from watchdog interrupt the code continues from this point.
  sleep_disable(); // Disable sleep mode after waking.
ISR(WDT_vect) {
  sleep_count++; // keep track of how many sleep cycles have been completed.
i hope it can be useful for somebody :grin:
very nice tnx :sunglasses:
* immediate searching in my junkbox but no thermistor to be found and a ‘normal’ tempsensor will never fit in memory I think
x560
Hi, are you using the attiny internal thermometer?
@Dennizr has added onto the miniaturized LMIC - originally for attiny by @rharte - would be interesting to see if that still works on the attiny! Would be my dream come true.
The library is here: https://github.com/Kaasfabriek/Junior_Internet_of_Things_2018/blob/master/Arduino_Junior_IOT_2018_5_slim_lmic_library/lmic_slim.zip
I believe it now uses all channels and has peer-to-peer capabilities as well. Feedback and improvements are welcome!
The sensor has an external thermistor on the ADC2 (PB4) input channel.
For channel switching simply add this switch statement in the RFM_Send_Package() function
// change the channel of the RFM module
  switch (TCNT0 % 3) {
    case 0x00: //Channel 0 868.100 MHz / 61.035 Hz = 14222987 = 0xD9068B
        break;
      case 0x01: //Channel 1 868.300 MHz / 61.035 Hz = 14226264 = 0xD91358
        RFM_Write(0x07,0x13);
        RFM_Write(0x08,0x58);
        break;
      case 0x02: //Channel 2 868.500 MHz / 61.035 Hz = 14229540 = 0xD92024
        RFM_Write(0x07,0x20);
        RFM_Write(0x08,0x24);
        break;
And if you would like to use a semi-random key to select the channel, just take a byte from the encrypted payload (or a byte from the MIC) and mask-out the 3 least significant bits as a pointer to the channel
Very nice, I have a few ATtiny’s and give it a try. Thanks for sharing!
@BoRRoZ, it will probably fit in memory easy but the question is if you have I/O available :slight_smile:
mmmmmmm… indeed :slight_smile:
a while back I bought a handfull of these boards for almost nothing… never used them.
reading this topic I installed the digispark driver and got blink to work :slight_smile:
https://diyprojects.io/tutorial-program-cjmcu-attiny85-lilytiny-lilypad/
comp
I made some Ampere Tests today with the node alone sending two dummy bytes every minute. During sleep the amperage was 0,24mA.
DSC_1245
With the thermistor connected, the current strength is slightly higher 0.39 mA due to the 10K resistor.
I do not know if I can bring it much lower. All tips are welcome !!!
DSC_1249
I think I found the solution with disabling the ADC ADCSRA &= ~(1<<ADEN);
in sleep mode saves about 235uA.
without sensor 5uA in sleep mode I am happy :yum:
And with the thermistor connected 153uA.
ttn
which bootloader do you use ?
will it work with v2.0 ?
why the bod @ 1v8 ?
I didn’t test with 2.0v yet and disabled the BOD for low power consumption.
Now I use this fuse settings -U lfuse:w:0x52:m -U hfuse:w:0xdf:m -U efuse:w:0xff:m
With the USBtinyISP for programming no bootloader is needed
Great example! thanks for share it will be so usefull for me, in this holidays i will work on a version which supports partially class c, wish me luck!
good luck :wink:
x565
some ATtiny85 eBay products
I like the ATtiny programmer shield it looks ancient. :joy:
Thanks for the extra effort of bitbanging all the low level stuff…
All credits go to Gerben den Hartog I only rearranged it a bit. :+1:
Sure … but It’s still nice to see a experimenal Lora version of the outdated Tiny TX concept from Nathan Chantrell…
I had succesfull working on this code to be used as class c, but the code i worked on was for an Arduino Pro Mini, now its time to port it to the Tinny if annyone needs somenthing like that for an arduino uno or pro mini i left the link to the gist.
I’m Working on the message decryption part right now but at least right now im receiving
Hope it be usefull!
I will keep working in this code, and create a repository but by now this is what i have :smiley:
It seems that you have a pin shortage on the ATtiny if you need DIO5 and you read from the RFM module.
SPI 4x (MISO,MOSI,SCK,SS) VCC, GND, DOI0,DIO5 that’s it nothing left for temp sensing.
