Arduino uno error no data received:(
I am using an Arduino Uno with an RC-SR04 ultrasonic sensor, and would like to forward the sendor data to the things network. I have a code that should connect us to the things network and calculate the distance. But when i look in the Serial Monitor it gives an error. I need help making this work.
Click to see code
* Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
* Permission is hereby granted, free of charge, to anyone
* obtaining a copy of this document and accompanying files,
* to do whatever they want with them without any restriction,
* including, but not limited to, copying, modification and redistribution.
* NO WARRANTY OF ANY KIND IS PROVIDED.
* This example sends a valid LoRaWAN packet with payload "Hello,
* world!", using frequency and encryption settings matching those of
* the (early prototype version of) The Things Network.
* Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in g1,
*  0.1% in g2).
* Change DEVADDR to a unique address!
* See http://thethingsnetwork.org/wiki/AddressSpace
* Do not forget to define the radio type correctly in config.h.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <CayenneLPP.h>  // installed using Sketch->Include Libary->Manage Libraries
// Values you have to change:
// search this document (strg+F) for "change next line" and change them or it won't compile
 * Pins for Pegelstand-PCB
int trigger=5;
int echo=4;
int done=12;
CayenneLPP lpp(51);
// LoRaWAN NwkSKey, network session key (msb)
// This is the default Semtech key, which is used by the prototype TTN
// network initially.
// !!!!!!!!!!!!!!!!!!!!!!!!! change next line:
static const PROGMEM u1_t NWKSKEY[16] ={"my nwkskey"};
// LoRaWAN AppSKey, application session key (msb)
static const u1_t PROGMEM APPSKEY[16] ={" my appskey"};
// LoRaWAN end-device address (DevAddr)
// See http://thethingsnetwork.org/wiki/AddressSpace
static const u4_t DEVADDR = "my devaddr" ; // <-- Change this address for every node!
// DISABLE_JOIN is set in config.h, otherwise the linker will complain).
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 60;
// Pin mapping for Dragino Lora Shield v95
    .nss = 10,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 9,
    .dio = {2, 6, 7},
void onEvent (ev_t ev) {
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            break;
        case EV_BEACON_FOUND:
            break;
        case EV_BEACON_MISSED:
            break;
        case EV_BEACON_TRACKED:
            break;
        case EV_JOINING:
            break;
        case EV_JOINED:
            break;
        case EV_RFU1:
            Serial.println(F("EV_RFU1"));
            break;
        case EV_JOIN_FAILED:
            break;
        case EV_REJOIN_FAILED:
            break;
            break;
        case EV_TXCOMPLETE:
              digitalWrite(done, HIGH);
             if (LMIC.txrxFlags & TXRX_ACK) {
            if(LMIC.dataLen) {
                // data received in rx slot after tx
                Serial.print(F("Data Received: "));
                Serial.write(LMIC.frame+LMIC.dataBeg, LMIC.dataLen);
                Serial.println();
            else
               Serial.print(F("No Data Received :("));
              // Serial.print(LMIC.dataLen);
            // Schedule next transmission
            break;
        case EV_LOST_TSYNC:
            break;
        case EV_RESET:
            break;
        case EV_RXCOMPLETE:
            // data received in ping slot
            break;
        case EV_LINK_DEAD:
            break;
        case EV_LINK_ALIVE:
            break;
         default:
            break;
void do_send(osjob_t* j){
    } else {
    lpp.reset();
    lpp.addAnalogInput(1,getdistance());
    LMIC_setTxData2(1, lpp.getBuffer(), lpp.getSize(), 0);
void setup() {
    Serial.begin(115200);
    pinMode(trigger, OUTPUT);
    pinMode(done, OUTPUT);
    pinMode(echo, INPUT);
    #ifdef VCC_ENABLE
    // For Pinoccio Scout boards
    pinMode(VCC_ENABLE, OUTPUT);
    delay(1000);
    #endif
    // LMIC init
    os_init();
    LMIC_reset();
    #ifdef PROGMEM
    LMIC_setSession (0x1, DEVADDR, nwkskey, appskey);
    #else
    LMIC_setSession (0x1, DEVADDR, NWKSKEY, APPSKEY);
    #endif
    // Set up the channels used by the Things Network, which corresponds
    // to the defaults of most gateways. Without this, only three base
    // channels from the LoRaWAN specification are used, which certainly
    // works, so it is good for debugging, but can overload those
    // frequencies, so be sure to configure the full frequency range of
    // your network here (unless your network autoconfigures them).
    // Setting up channels should happen after LMIC_setSession, as that
    // configures the minimal channel set.
    LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
//  LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI);      // g-band
//    LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
//    LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
//    LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
//    LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
//  LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
//   LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
//  LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK,  DR_FSK),  BAND_MILLI);      // g2-band
    // TTN defines an additional channel at 869.525Mhz using SF9 for class B
    // devices' ping slots. LMIC does not have an easy way to define set this
    // frequency and support for class B is spotty and untested, so this
    // frequency is not configured here.
    LMIC_setLinkCheckMode(0);
    LMIC.dn2Dr = DR_SF9;
    // Set data rate and transmit power (note: txpow seems to be ignored by the library)
    LMIC_setDrTxpow(DR_SF7,14);
    // Start job
    do_send(&sendjob);
void loop() {
    os_runloop_once();
uint8_t getdistance(){
  long duration=0;
  uint8_t distance=0;
  digitalWrite(trigger, LOW);
  delay(5);
  digitalWrite(trigger, HIGH);
  delay(10);
  duration = pulseIn(echo, HIGH);
  distance = (duration/2) * 0.03432;
  if (distance >= 500 || distance <= 0)
    Serial.println("Kein Messwert");
  else
    Serial.print(distance);
    Serial.println(" cm");
  return distance;
Error:
39 cm
Packet queued
77784903: EV_TXCOMPLETE (includes waiting for RX windows)
No Data Received :frowning:
an arduino uno doesn’t have LoRaWAN possibillities.
what type of gateway do you use … single channel ?
  • please format your code (I did that for you)
are you sending downlinks from the network to the node? If not, you cannot expect to receive data…
Please be more specific about the hardware you are using… I see you taged dragino… posting a picture would give us more info on what could be wrong.
Thank you for your response.
20190507_093547
20190507_093246
20190507_093308
20190507_093214
My first reaction would be: are you sure you have the right paramters in LMIC (for dragino)? and did you try to send a value directly to TTN-backend (without using Cayenne) and did it arrive? (to check if communication is working)
