Arduino Uno / Dragino - Radar Senor Data to TTN
Dear forum participants,
Currently I am testing with an
Arduino UNO, Dragino Shield v1.4,
to transfer the distance values of a radar sensor into the TTN.
The radar sensor is connected via Pin3 and Pin4 (at the plugged Dragino Shield).
(3,4 pin selection was made because these are not occupied by Dragino Lora Shield and the sensor data can be displayed in the serial monitor).
To test the Dragino/Uno connection to TTN,I used a “HelloWorld”-Sketch ->Works!
To test the sensor and display the distance values in the Serial Monitor I used another test script. ->Works!
Now I would have to combine the two sketches to send the distance values to TTN.
Can you give me a few tips in this regard?
Lora-TTN-HelloWorld:
#include <lmic.h>
#include <hal/hal.h>
#ifdef CREDENTIALS
static const u1_t NWKSKEY[16] = NWKSKEY1;
static const u1_t APPSKEY[16] = APPSKEY1;
static const u4_t DEVADDR = DEVADDR1;
#else
static const u1_t NWKSKEY[16] = { 0xXX, 0xXX, 0xXX, 0xXX,0xXX, 0xXX, 0xXX, 0xXX,0xXX, 0xXX, 0xXX, 0xXX,0xXX, 0xXX, 0xXX, 0xXX,};
static const u1_t APPSKEY[16] = { 0xXX, 0xXX, 0xXX, 0xXX,0xXX, 0xXX, 0xXX, 0xXX,0xXX, 0xXX, 0xXX, 0xXX,0xXX, 0xXX, 0xXX, 0xXX,};
static const u4_t DEVADDR = 0x12345678;
#endif
// DISABLE_JOIN is set in config.h, otherwise the linker will complain).
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 60;
// Pin mapping Dragino Shield
    .nss = 10,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 9,
    .dio = {2, 6, 7},
void onEvent (ev_t ev) {
    if (ev == EV_TXCOMPLETE) {
        // Schedule next transmission
void do_send(osjob_t* j){
    // Payload to send (uplink)
    static uint8_t message[] = "HelloWorldDragino";
    } else {
        LMIC_setTxData2(1, message, sizeof(message)-1, 0);
        Serial.println(F("Sending uplink packet..."));
void setup() {
    Serial.begin(115200);
    Serial.println(F("Starting..."));
    // LMIC init
    os_init();
    LMIC_reset();
    // Set static session parameters.
    LMIC_setSession (0x1, DEVADDR, NWKSKEY, APPSKEY);
    LMIC_setLinkCheckMode(0);
    LMIC.dn2Dr = DR_SF9;
    // Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
    LMIC_setDrTxpow(DR_SF12,14);
    // Start job
    do_send(&sendjob);
void loop() {
    os_runloop_once();
Radar-Sensor SoftSerial-Test:
#include <SoftwareSerial.h>
SoftwareSerial RadarSerial(4, 3);
void setup() {
 Serial.begin(19200);
 // set the data rate for the SoftwareSerial port
 RadarSerial.begin(19200);
void loop() { // run over and over
 if (RadarSerial.available()) {
   Serial.write(RadarSerial.read());
 if (Serial.available()) {
   RadarSerial.write(Serial.read());
Thank you very much in advance
Can you show us what RadarSerial.read() returns so we can give you pointers on how to format the payload.
And what do you send to RadarSerial.write() ??
Hello!
Thanks for pointing this out to me.
I forgot to specify the output.
“Serial.read” does not work,therefore I use “Serial.write”, or “Serial.println”
to display the distance value in a Serial Monitor.
Using,
RadarSerial.write()
the distance value in the Serial Monitor is output in readable format.
Serial.write - Output Example (2.2 Meter):
2.2
Using,
RadarSerial.println()
the distance value in the Serial Monitor is output in ASCII format
Serial.println - Output Example (2.2 Meter):
50 (2)
46 (.)
50 (2)
13 (\r carriage return)
10 (\n newline)
I’m a bit new but this looks like “hello world”. it is sending the variabe called “message” but that is defined as “HelloWorldDragino” Prehaps it would be easire to start with a sketch that is sending sensor data?
here i have two sensors and thier values are the payload. the variables are humidity and temperature
// Split both words (16 bits) into 2 bytes of 8
byte payload[4];
payload[0] = highByte(humidity);
payload[1] = lowByte(humidity);
payload[2] = highByte(temperature);
payload[3] = lowByte(temperature);
ttn.sendBytes(payload, sizeof(payload));
So you need to read the radar and then put that value into a variable, in the code you posted it just pushes it out on seriel. You could read it once or a few times and average it then send it out. You need some long pause in this loop though so that you are not constantly sending over the air waves like serial does over the usb cable.
See here… I read my sensor and put those values into the variables… the (false) is just something about the type of data i am getting false means I get celcuis.
uint16_t humidity = dht.readHumidity(false);
uint16_t temperature = dht.readTemperature(false);
Thank you for your suggestion.
I have found at: https://www.thethingsnetwork.org/docs/devices/bytes.html
how to deal with decimals.
I think that would be more appropriate (“2.2” for example) in my case or?
byte payload[1];
payload[0] = round(RadarSerial * 100);
ttn.sendBytes(payload);
No it isn’t, please use 10 additional seconds to format your post.
To deal with decimals you can do *100 on the device side and then /100 on the other end.
In your example you use the
#include <TheThingsNetwork.h>
library.
But for the Dragino-Shield I have to use the LMIC library
#include <lmic.h>
right?
Yes, the first is for the TTN Node, the second is for devices that don’t have a pre-built module inside, just a radio chip.
You need to store the value and send it. The hello world one just sends “HelloWorldDragino” So instead of sending the exact text between the “” signs you should send the distance value stored in the variable.
