I would like to know if it is possible to use an Arduino card with a Lora module. And if you would have the reference of the Lora module as well as the compatible Arduino cards.
It is possible to use an Arduino board with a LoRa module.
It would, however, be a long list, there are a great many boards and microcontrollers that can be used with the Arduino IDE.
Although be aware that boards such as those based on the ESP32, are not ‘Arduinos’ as such, since Arduino do not make them. They are just boards that can be programmed through the Arduino IDE.
There are also a fair range of LoRa modules out there.
Whats the application ?
