I have LoraWan setup ( Ardunio with some sensors connected to Multitech mlinux Lora Gatway connected to thethingsnetwork using OTT) i am receiving the data here but i want to virtualization the data ( location on map and vibration …ect) on backend app. I am am trying to visualizer my data on All Things talk but i can’t find much information.
Anyone have done a project throught All things talk ? Can any one help me with that please ?
This is great! I have just run through the connection process with my Things Node. Once you’ve added your device on AllThingsTalk you need to add assets - one for battery, one for light, one for temperature - if you are using the Things Node basic sketch. Then you need to add a small bit of code to tell their binary converter thing what to do. To save you time, the code that works nicely is:
I am struggling to get All Things Talk working with TTN.
I have read over the documentation but can not seem to get any data through to ATT.
The details earlier in this topic look simple enough, but buggered if I can get it to work.
I have devices on my TTN setup that have been previously sending data through to Cayenne without any major issue.
I have now removed the Cayenne integration from my application and replaced it with a ATT one.
I have also removed the LPP payload conversion (now set to custom).
I have a node that sends LPP style data (byte format) and I have added payload conversion stuff to my ATT ground (ABCL JSON conversion code to just pick up the bytes I need from the data).
I can see the data in the application console at the TTN but absolutely nothing seems to make its way to the ATT end.
I believe I have entered all the required TTN info correctly (dev_eui, app_eui, appskey, app-id, etc).
I am located in Australia but using the asia-se handler for my application. Not sure whether this has any bearing on the data not being seen. Maybe I have to use the eu-handler.
