After upgrading Semtech mote to MAC version 04.04.02.00, OTAA no longer works with The Things Gateway?
Is Semtech MAC version 04.040.02.00 supported by The Things Gateway ?
It looks like I’m not able to join .
The gateway is just a dumb air to IP forwarder which does not care about MAC versions. It only requires LoRaWAN packets with a valid CRC.
Thanks for your comment Jac. I have updated a mote to Semtech MAC version 04.04.02.00 and it seems the join procedure is not working anymore on TTN.
In ABP mode it works.
On other network , like Proximus MyThings and Multitech , I see no problem.
My guess is an back-end incompatibility issues. Not a gateway issue. Is that MAC (got a link?) LoRaWAN 1.0.2 compatible?
It should be LoRaWAN version 1.0.3 March 2018 compatible.
see : https://www.st.com/resource/en/data_brief/i-cube-lrwan.pdf
