In an urban environment, some sensors are running, reciving signals is at limit and packets arrive only sporadically.
Now I tested the ADR behavior of an OTTA node after I switched off the GW.
As expected, the data rate is reduced.
At DR1 the first reception came (other GW) and the data rate is increased immediately to DR5. Now no packkets arrived!
RX on freq 868500000 Hz at DR 1
Event : Rx Timeout
RX on freq 869525000 Hz at DR 3
Event : Rx Timeout
unconfirmed uplink sending …
TX on freq 867300000 Hz at DR 1
Event : Tx Done
RX on freq 867300000 Hz at DR 1
Event : Rx Timeout
Event : Rx Timeout
TX on freq 868300000 Hz at DR 1
Event : Tx Done
RX on freq 868300000 Hz at DR 1
Event : Rx Timeout
Event : Rx Timeout
TX on freq 867500000 Hz at DR 1
Event : Tx Done
RX on freq 867500000 Hz at DR 1
Event : Rx Timeout
Event : Rx Timeout
Event : Tx Done
Event : Rx Done
received unconfirmed downlink: rssi = -113, snr = -14, datarate = 1
TX on freq 867300000 Hz at DR 5
Event : Tx Done
RX on freq 867300000 Hz at DR 5
Event : Rx Timeout
Event : Rx Timeout
TX on freq 867500000 Hz at DR 5
Event : Tx Done
RX on freq 867500000 Hz at DR 5
Event : Rx Timeout
Event : Rx Timeout
So i think the parameter of ADR must be optimized!
Greetings
E_T
