Where is the access key I can use to authenticate against the Application Manager API over REST? I can see access keys https://console.thethingsnetwork.org/applications/xxx/settings/access-keys, but the value isn’t visible. I can create new ones, but even after doing that the actual key is not shown. It just shows a list of access key names. Thank you!
Found it! On the General tab it’s at the bottom!
As at August 2020 there are no access keys shown on the Application ‘General Tab’ as suggested. However they can be found on the ‘Application Overview’ tab. Just scroll down to the bottom.
I don’t see it, and I cannot scroll down
Please don’t double post, not good use of all the volunteers time - which one should they answer?
PS, the 1 year old thread above relates to v2.
