ABP downlink frame counter issue after resetting the node
How can I reset the downlink framecounter for a node that uses ABP activation?
This is for testing purposes.
(Reset Frame Counters is enabled for the device.)
Mmm, I tried to reset the node several times (even with some 8 minutes in between), which reset the uplink frame counter to 0 but the downlink frame counter just kept incrementing.
Some moment later I reset the node again and suddenly the downlink frame counter was reset to 0 again (as expected).
When I reset the node again, e.g. after 20 seconds the downlink counter also starts at 0 again.
Murphy?
CLI:
ttn-lw-cli end-devices set [application-id] [device-id] --session.last-a-f-cnt-down 0
Is there a way with the TTN-Console?
E_T
Ok, i found a hook box “Enable reset frame counter”!
