In the meanwhile, you could try adding the device again, but ensuring you check the Resets Frame Counters - it doesn’t work so well if you do it after you’ve created the device.
And these are ALL of the EU frequencies (which also apply to UK, Swiss & EEA Bees).
Sorry, I didn’t catch the accuracy of your question : on the concerned device, I have 2 scales , 1 voltage, 1 T° , that is to say 30 or 33 bytes for payload .
Is it the responses you expect ?
Here is one received message copied from the gateway console V3:
19:36:17 Receive uplink message DevAddr 260BA800 FPort 1
MAC payload A519304F80688C42BB2F21539A0A063BC30D0BA1
Bandwidth 125000
SNR 7.5
RSSI -31
Raw payload 4000A80B2680000001A519304F80688C42BB2F21539A0A063BC30D0BA10A5BCD2F
DHT 21/22 is configured but I don’t implement it .
I use the T° information from the DS3231 module (RT clock)
For Volt, Nano board analog input are used.
I have to go on the hives but the weather is really poor (let’s say a bit Brit…). We will have to wait until bees can go out also …
I will have the time to read more .
Thanks anyway
This was the right direction : with an updated library ,tonight i have some better results. Some messages are properly decoded at the level of the console. They do not reach my server presently but it’s a great step already. Tomorrow is an other day !
Thanks for your help. It has been a pleasure to fly with you a moment.
See you later.
Analog out fort Volts, luminosity for Weight, T° for Temperature. This work fine now with the proper LMIC library .
Now I have to understand why I cannot read the MQTT server V3 such as in V2 . But this is an other topic , if I have well understood.
Bye on that one.
That is a ‘feature’ (according to some, others consider it the error it is) of the V3 backend. You can start your counter at one if you want to or just catch the ‘missing’ field by defaulting it to zero.
