A command line lora calculator for developer
Finally, I am tired of the Semtech GUI tool and the customized Excel sheets, let’s move to the elegant cmdline tool together .
Source code: https://github.com/JiapengLi/lorcalc
And how to use it:
./lrc -h
Usage: lrc [OPTIONS]
 -h, --help                                      Help
 -v, --version                                   Version 0.0.1
 -b, --bw,   --bandwidth                 <uint>  Bandwidth in hz, eg: 125000, 250000, 203125
 -s, --sf,   --spread-factor             <uint>  Spread factor (5 - 12)
 -o, --ldro, --low-datarate-optimize     <bool>  Low datarate optimize (on / off)
 -f, --fs,   --fine-synch                <bool>  Fine synch for high speed lora SF5 and SF6,
 -i, --li,   --long-interleaving         <bool>  Available in 2.4GHz lora (sx128x)
 -c, --cr,   --coderate                  <uint>  coding rate CR4/5 CR4/6... (1 - 4)
 -r, --pr,   --preamble                  <uint>  Raw preamble lenght
 -d, --hdr,  --header                    <bool>  Header option (on / off)
 -k, --crc,                              <bool>  CRC option (on / off)
 -l, --pl,   --payload                   <uint>  payload length
Moderator edit - surely you meant sheets?
