865-868MHz Patch Antenna on PCB
I didn’t have much time but I had the antenna design tested/measured. The results are satisfying but not perfect yet.
Ideal for short range but this antenna design won’t reach more than a couple of km’s.
The frequency is a bit off the centre (about 30MHz) to match 868MHz so that’s going to be fixed in the next hardware revision.
