RAK831 USA 915 MHz not working probably
Ate the moment i’m trying to get the RAK831 working for in Brasil, in Brasil we use the same frequencies as in the USA. I used the following tutorial:
https://www.thethingsnetwork.org/labs/story/rak831-lora-gateway-from-package-to-online
I have the same kit as in the tutorial, but for 915 MHz.
I did read the following post: The hard RAK831 cafe part 1
But without any luck, in most cases I don’t receive nothing. Sometime i get some LoRa packets, but with a really bad RSSI on a really close distance.
Does somebody have the same problem?
I’m using the following global_conf.json
"SX1301_conf": {
	"lorawan_public": true,
	"clksrc": 1,
	"clksrc_desc": "radio_1 provides clock to concentrator",
	"antenna_gain": 0,
	"antenna_gain_desc": "antenna gain, in dBi",
	"radio_0": {
		"enable": true,
		"type": "SX1257",
		"freq": 904300000,
		"rssi_offset": -166.0,
		"tx_enable": true,
		"tx_freq_min": 923000000,
		"tx_freq_max": 928000000
	"radio_1": {
		"enable": true,
		"type": "SX1257",
		"freq": 905000000,
		"tx_enable": false
	"chan_multiSF_0": {
		"desc": "Lora MAC, 125kHz, all SF, 903.9 MHz",
		"enable": true,
		"radio": 0,
		"if": -400000
	"chan_multiSF_1": {
		"desc": "Lora MAC, 125kHz, all SF, 904.1 MHz",
		"enable": true,
		"radio": 0,
		"if": -200000
	"chan_multiSF_2": {
		"desc": "Lora MAC, 125kHz, all SF, 904.3 MHz",
		"enable": true,
		"radio": 0,
		"if": 0
	"chan_multiSF_3": {
		"desc": "Lora MAC, 125kHz, all SF, 904.5 MHz",
		"enable": true,
		"radio": 0,
		"if": 200000
	"chan_multiSF_4": {
		"desc": "Lora MAC, 125kHz, all SF, 904.7 MHz",
		"enable": true,
		"radio": 1,
		"if": -300000
	"chan_multiSF_5": {
		"desc": "Lora MAC, 125kHz, all SF, 904.9 MHz",
		"enable": true,
		"radio": 1,
		"if": -100000
	"chan_multiSF_6": {
		"desc": "Lora MAC, 125kHz, all SF, 905.1 MHz",
		"enable": true,
		"radio": 1,
		"if": 100000
	"chan_multiSF_7": {
		"desc": "Lora MAC, 125kHz, all SF, 905.3 MHz",
		"enable": true,
		"radio": 1,
		"if": 300000
	"chan_Lora_std": {
		"desc": "Lora MAC, 500kHz, SF8, 904.6 MHz",
		"enable": true,
		"radio": 0,
		"if": 300000,
		"bandwidth": 500000,
		"spread_factor": 8
	"chan_FSK": {
		"desc": "FSK disabled",
		"enable": false
	"tx_lut_0": {
		"desc": "TX gain table, index 0",
		"pa_gain": 0,
		"mix_gain": 8,
		"rf_power": -6,
		"dig_gain": 0
	"tx_lut_1": {
		"desc": "TX gain table, index 1",
		"pa_gain": 0,
		"mix_gain": 10,
		"rf_power": -3,
		"dig_gain": 0
	"tx_lut_2": {
		"desc": "TX gain table, index 2",
		"pa_gain": 0,
		"mix_gain": 12,
		"rf_power": 0,
		"dig_gain": 0
	"tx_lut_3": {
		"desc": "TX gain table, index 3",
		"pa_gain": 1,
		"mix_gain": 8,
		"rf_power": 3,
		"dig_gain": 0
	"tx_lut_4": {
		"desc": "TX gain table, index 4",
		"pa_gain": 1,
		"mix_gain": 10,
		"rf_power": 6,
		"dig_gain": 0
	"tx_lut_5": {
		"desc": "TX gain table, index 5",
		"pa_gain": 1,
		"mix_gain": 12,
		"rf_power": 10,
		"dig_gain": 0
	"tx_lut_6": {
		"desc": "TX gain table, index 6",
		"pa_gain": 1,
		"mix_gain": 13,
		"rf_power": 11,
		"dig_gain": 0
	"tx_lut_7": {
		"desc": "TX gain table, index 7",
		"pa_gain": 2,
		"mix_gain": 9,
		"rf_power": 12,
		"dig_gain": 0
	"tx_lut_8": {
		"desc": "TX gain table, index 8",
		"pa_gain": 1,
		"mix_gain": 15,
		"rf_power": 13,
		"dig_gain": 0
	"tx_lut_9": {
		"desc": "TX gain table, index 9",
		"pa_gain": 2,
		"mix_gain": 10,
		"rf_power": 14,
		"dig_gain": 0
	"tx_lut_10": {
		"desc": "TX gain table, index 10",
		"pa_gain": 2,
		"mix_gain": 11,
		"rf_power": 16,
		"dig_gain": 0
	"tx_lut_11": {
		"desc": "TX gain table, index 11",
		"pa_gain": 3,
		"mix_gain": 9,
		"rf_power": 20,
		"dig_gain": 0
	"tx_lut_12": {
		"desc": "TX gain table, index 12",
		"pa_gain": 3,
		"mix_gain": 10,
		"rf_power": 23,
		"dig_gain": 0
	"tx_lut_13": {
		"desc": "TX gain table, index 13",
		"pa_gain": 3,
		"mix_gain": 11,
		"rf_power": 25,
		"dig_gain": 0
	"tx_lut_14": {
		"desc": "TX gain table, index 14",
		"pa_gain": 3,
		"mix_gain": 12,
		"rf_power": 26,
		"dig_gain": 0
	"tx_lut_15": {
		"desc": "TX gain table, index 15",
		"pa_gain": 3,
		"mix_gain": 14,
		"rf_power": 27,
		"dig_gain": 0
"gateway_conf": {
	"gateway_ID": "",
	"server_address": "router.us.thethings.network",
	"serv_port_up": 1700,
	"serv_port_down": 1700,
	"servers": [ {
		"serv_enabled": true
What are you using for an antenna?
This evening, standing on the roof of a 13-story building in Boston, USA holding a TTN node I turned on TTN Mapper and was quickly told that I had successfully passed a packet (RSSI -97) to a gateway that I understand to be a Raspberry Pi with RAK831 USA frequency, located indoors about 3000 meters away. Not sure what that device’s antenna is.
On the RAK831 i use the antenna that comes with it. On the RN2903 i use also the antenna that got delivered with it. Also tried wire antennas at a 1/4 wavelength, but no different. I have the feeling there is a mismatch in the configuration. If i receive a msg (almost never) on a distance of less than 5 meters, the RSSI is around -120.
That funny. With a RFM95, with the following setting “LMIC_selectSubBand(1);” the rak831 is receiving correctly. With the gateway form Microchip I used the following setting “LMIC_selectSubBand(0);” Could it be the RN2903 is configured incorrectly? I will have a look later on.
#elif defined(CFG_us915)
// NA-US channels 0-71 are configured automatically
// but only one group of 8 should (a subband) should be active
// TTN recommends the second sub band, 1 in a zero based count.
// gateway-conf/US-global_conf.json at master · TheThingsNetwork/gateway-conf · GitHub
#endif
