I finely got my TTGO V2.1 T3_V1.5 20180523 with Paxcounter v1.3.82
The DEVEUI is shown in the first display. Now I wonder how to see the data if it is picked up.
Did not manage to connect to any gateway with the pre installed software. Installed V1.3.91 with my DevEUI and AppEUI.
Display came the right way and it connected in seconds from my home. 8 km to the closest gatway.
I see new data every 1-2 min, but I do not find the data or payload. Maybe I need some integrator?
Found it. Maybe two gateways got the signal.Nice
If the dev addr changes for each message, your device contiously rejoins.
Check on serial console if the device is in a reset loop, but this should be cleary visible on the display, too.
If you do not see status “TX COMPLETE”, only status “PACKET QUEUED” on display, the device is not sending payload data, because it either reached duty cycle or the LoRa chip does not trigger the event, what is typically caused by missing or erraneous wiring of DIO1 pin of LoRa chip or wrong pin setting in the .h file.
It is working better today.
First it changes dev addr on every line with activation. Then it starts to send payload every 4 min. Then after 10 uplinks on port 1 it start to also to do downlink on port 0.
Now there is a downlink after every uplink, and I see three different gatways gets the data. So moving the antenna up 30 cm and holding it vertical maks a great improvments in reach.
We are currently building the camp site facilities for two big scout camps in the Netherlands and we are registering the restaurant occupancy using a PAX counter connected to the temporary TTN coverage on the camp-site
