We have a device (from Elsys) working and transmitting data periodically. It is being received by a number of gateways, but we are seeing duplicate metadata when we inspect the individual packets … and moreover whilst the gateway ID is the same, some of the actual metadata is different … does anyone know what is going on?
If I look at an individual received packet in the TTN Console … e.g. Applications -> elsys-elt2-mb7389-ttn -> Data
I’ll see …
Clicking on the up-triangle there lets me see the detailed data and meta-data, and the latter shows me which gateways received the packet.
You don’t need to read this, but it looks like this …
Here is the actual metadata, hopefully legible this time …
"time": "2020-04-14T19:38:00.87002551Z",
"frequency": 867.7,
"modulation": "LORA",
"data_rate": "SF12BW125",
"coding_rate": "4/5",
"gateways": [
"gtw_id": "eui-a840411d1f0c4150",
"timestamp": 1390247508,
"time": "2020-04-14T19:38:00.847405Z",
"channel": 6,
"rssi": -49,
"snr": 9.2
"gtw_id": "eui-b827ebfffec0c17b",
"timestamp": 4287703196,
"time": "2020-04-14T19:37:59.816229Z",
"channel": 6,
"rssi": -41,
"snr": 9.5,
"latitude": 51.45733,
"longitude": -0.21949,
"altitude": 55
"gtw_id": "eui-b827ebfffebbe35f",
"timestamp": 2679433092,
"time": "2020-04-14T19:38:00.849584Z",
"channel": 6,
"rssi": -54,
"snr": 11,
"latitude": 51.45725,
"longitude": -0.21874,
"altitude": 27
"gtw_id": "eui-b827ebfffe5852a9",
"timestamp": 4167918644,
"time": "2020-04-14T19:38:00.85149Z",
"channel": 5,
"rssi": -89,
"snr": -15.2,
"latitude": 51.45731,
"longitude": -0.2191,
"altitude": 30
"channel": 6,
"rssi": -46,
"snr": 10.2,
"altitude": 30
"gtw_id": "eui-a840411b7c544150",
"timestamp": 4196549252,
"time": "2020-04-14T19:38:00.86441Z",
"channel": 6,
"rssi": -64,
"snr": 10.8
"gtw_id": "eui-60c5a8fffe74d31e",
"timestamp": 369925268,
"time": "",
"channel": 6,
"rssi": -47,
"snr": 10.8,
"altitude": 34
"gtw_id": "eui-b827ebfffe45866e",
"timestamp": 3541415508,
"time": "2020-04-14T19:38:00.873465Z",
"channel": 6,
"rssi": -59,
"snr": 9.5
"timestamp": 3541415532,
"channel": 5,
"rssi": -90,
"snr": -8.8
"gtw_id": "eui-58a0cbfffe800555",
"timestamp": 499739100,
"time": "2020-04-14T19:38:00.860600948Z",
"channel": 0,
"rssi": -49,
"snr": 10.25
"gtw_id": "sentriusrg186-putneyhill",
"gtw_trusted": true,
"timestamp": 49116660,
"time": "",
"channel": 6,
"rssi": -47,
"snr": 9.5,
"latitude": 51.457245,
"longitude": -0.21874009,
"altitude": 30
"gtw_id": "eui-3232393456005e00",
"timestamp": 3262074252,
"time": "",
"channel": 6,
"rssi": -37,
"snr": 7.3
"gtw_id": "ttngateway-putneyhill-londonsw15",
"timestamp": 348184516,
"time": "2020-04-14T19:37:55Z",
"channel": 6,
"rssi": -47,
"snr": 10.25,
"longitude": -0.21928726,
"altitude": 30,
"location_source": "registry"
"gtw_id": "ttn-001-868-new",
"timestamp": 1473319940,
"time": "2020-04-14T19:38:07Z",
"channel": 6,
"rssi": -49,
"snr": 9.5
The gateways eui-b827ebfffe5852a9
and eui-b827ebfffe45866e
appear twice …
First instance …
"channel": 5,
"rssi": -89,
"snr": -15.2,
"altitude": 30
Second instance …
"channel": 6,
"rssi": -46,
"snr": 10.2,
"altitude": 30
So, same gtw_id and timestamp, but different values for channel, rssi and snr.
Likewise:
"channel": 6,
"rssi": -59,
"snr": 9.5
and:
"channel": 5,
"rssi": -90,
"snr": -8.8
Again the same gtw_id and different values for channel, rssi and snr, and also different timestamps.
