I got confused after read all the discussion here how to calculate that how many sensors can be severed by a gateway. If we take 24 hours as the time period, and all the 8 channels are used at a gateway, duty cycle is 5%, and SF is 7-12. If we assume the packet arrival data is \lambda which follows PPP. How to get a theoretical value for the maximal number of sensors covered by a single gateway? @Thomas
It is true this: Wavion is the best cost / efficiency / number of nodes / reach system?
WaviotâŚ
@aliekens @scle
If we look at the joining message, itâs is totally up to the end-device to choose the SF and central frequency to send a joining request to gateway. The collisions for joining message must be very high. Joining message delay is also comparatively large. Even in the case, where there are only 5 devices under a gateway sending joining request message, the message will collide. Did you simulate for that? What are your views about it?
Hardly can find this absolutely true. Although, the messages, of course, MAY collide.
Hereâs a conclusion from a recent article regarding LoRaWAN scalability:
âDo Long Range (LoRa) Low-Power Wide-Area Network(LPWAN) scale? According to our study presented in the paper current installations based on LoRaWAN do not. (âŚ) However, our study also shows that LoRa networks can scale quite well if they use dynamic transmission parameter selection and/or multiple sinks. For both aspects more work is required as protocols for dynamic transmission parameter selection and strategies for useful sink deployment must be developedâ
Interestingly, the article doesnât mention Adaptive Data Rate (ADR), at least not in those words. Possibly because itâs not implemented in current networks (e.g. see https://github.com/TheThingsNetwork/ttn/issues/265 )
Isnât ADR a part of this?
Exactly, which is why I wrote âat least not in those wordsâ. I was under the impression that ADR was the terminology that Semtech / Lora Alliance generally used for this - so I was a bit surprised they didnât mention that term when the whole article revolves around this topic, almost as if they didnât realize this is already being developed (and possibly already in place in some implementations?).
Definitely already in place in some implementations.
Some discussion on this in the comments at https://www.linkedin.com/pulse/how-many-devices-does-one-lorawan-gateway-support-120-jay-wey
Another interesting read
Well written article. As the authors say, indeed an impartial and fair overview of the capabilities and limitations of LoRaWAN.
some small remarks:
- The 500kHz channel the authors mention is not available in Europe, and in the US itâs only used for downlink. Therefore the max data rate is actually a bit lower.
- The authors only consider 3 channels. During a join, the network configures 5 additional channels (bringing the number to 8). Using MAC commands we could configure even more channels if the gateway is configured to handle those.
Iâm puzzled by the scale in packets/hour theyâve chosen
Most applications Iâve seen for LoRaWAN requires a packet every 1 to 15 minutes (so 4 to 60 pkt/h) but for whatever reason the authors of the article chose to show curves for up to several thousands of packets/hour. Do they thinks itâs some kind of âlong range Wifiâ? Thousands of packets/hour also mean draining a battery fast, and itâs not what those class of networks were designed for, itâs even in the name: LPWAN, for Low Power Wide Area Network.
Sylvain, the discussion is not about how many messages a device can send, but how many a gateway can receive. Considering that a gateway has a range of multiple kilometers, it is not unthinkable in an urban setting that there are 1000 devices sending 1 message per minute. At these rates, the public ether becomes plugged up.
Donât forget a gateway picks up all messages from all networks. E.g. your TTN gateway will also pick up the messages from other telcoâs operating a LoraWan network in the same region and vice versa.
Thousands of devices per gateway isnât unreasonable. E.g. in a mid-sized Western European city, there are around 2.000 utility meters per square kilometer. If a utilities company chooses LoraWan to communicate quarter-hourly meter readings, youâre looking at 4.000 messages/hour/km², for this application alone.
That is assuming all networks use the same optional frequencies for EU868 or same band for US915/AU915.
Afaik all currently operational networks do?
