The information about v3 is overwhelming for me. My setup is very very simple:
a) I operate only one official public The Things Gateway
b) I operate one sensor (in one application in the console) that is sending data
And would like to understand…
…how can I upgarde my current applications to v3 (I assume mine is still V2 as the only console I know is also the v2 console: https://console.thethingsnetwork.org). I do not find any hint about the version of my application in the console.
…how could I (in theory) upgrade the gateway to v3? There is no other configuration than the WiFi Settings available when I browse to the gateway IP. (I know that I shall not update my gateway today to v3 as this would affect all other users as well, but I was expecting at least the option to initiate it somehow.
Thanks for shading any light on this topic for me
Flo
@wolli
it makes sense to ask your questions in English because this is an international forum. If you want to get help in German language ask your local community on their Slack-channel.
If you feel you must post in local laguauge - perhaps helps in getting local support - you should also double post in English - even if just with Google Translate - its a start! That way you may get faster, broader response and also helps wider community with developing the pool of information on the forum
e.g. Wenn Sie der Meinung sind, dass Sie in lokaler Sprache posten müssen - vielleicht hilft es Ihnen, lokale Unterstützung zu erhalten, sollten Sie auch doppelt auf Englisch posten - auch wenn dies nur mit Google Translate geschieht - es ist ein Anfang! Auf diese Weise erhalten Sie möglicherweise eine schnellere und umfassendere Antwort und können eine breitere Community bei der Entwicklung des Informationspools im Forum unterstützen
ALL - It may be worth your while keeping an eye on, bookmarking & following this thread where we are trying to consolidate, highlight and resolve (where possible) issues arising from the transition, or give approropriate guidance and potential supporting links.
