Core Electronics for the Laird. Elecom for the Multitech.
I’m looking to get into LoRaWAN and am on a very low budget. I see that only verified devices can connect to the network and they must adhere to the right regions. I found the the CubeCell – Dev-Board from China for $30 delivered is this a good starting device which will be compatible with this network?
This one seems to be compatible with your region
Is this dashboard still live?
Alas no, it died along with TheDash. It looked a bit like this.
I tried one of these about a year ago and it worked straight out of the box. Just choose the 900Mhz version.
Dave
What is the consensus on a frequency plan for the Newcastle region, I plan to migrate my gateway from AS920-923 to AU915 later this year when I move to the recently released V3 stack.
What frequency plans are other gateways in the area running on and do you have any plans to move them over?
The Newcastle & Lake Macquarie community will adopt the national consensus, which is set to be established tonight. As you’ve already discovered, this topic is being debated right now, and a pretty clear consensus is emerging:
