TTN Mapper size of measurement point circles
seems to be an easy question, but I was not able to find an answer.
The circles (heatmap mode) representing measured locations, have color and a size. While the color is obvious from the legend (signal strength) I’m not sure what the size of the circles are showing.
GPS accuracy (the larger the circle the less accurate) would make sense to me, but if I look at the measurements here around me it seems that the weaker the signal the larger the circle.
Wouldn’t make too much sense to me.
Can someone enlighten me?
By the way - it seems to me that the beams in beam mode also have different width. But here I’m not sure, since they get wider anyhow the longer they are (I guess that’s the nature of a beam).
While I’m writing this it comes to my mind, that it might be the same with the circles? That they are kind of endpoints of beams and therefore larger the more away from the gateway (and with that in most cases the weaker the signal)?
Thanks Christian
Must confess I wondered on this myself in the past but then figured also related to SF used with lower signals on higher SF and hence longer time on air and potential wider ‘uncertainty’ of position wrt any potential distance moved around the measured point assuming potential motion during tx?! :man_shrugging: Another data presentation question for @jpmeijers to comment on? Given end point tends to a small area which grows with poor signals or higher/longer SF’s then outer boundaries of any beams also then wider…?
Maybe this slide will explain it:
See: https://www.youtube.com/watch?v=Y9lMvyTYI3E&t=1006s
OK, makes sense!
Thank you!
