No luck registering for me. I’m seeing it fetching the configuration:
CNFG: Load online user config state change to 6
FREQ: APP_URL_Buffer: https://account.thethingsnetwork.org/api/v2/frequency-plans/EU_863_870
HTTP: Starting connection
HTTPS: Connection Opened: Starting TLS Negotiation
HTTP: Wait for TLS Connect
MON: SYS Stack size: 2855
MON: heap usage: 227KB (233KB), free: 111KB
HTTP: TLS Connection Opened: Starting Clear Text Communication
HTTP: Got 1232 bytes
HTTP: Connection Closed
HTTP: Close active socket 1
…but then it logs LORA: Configuration failed, retry (like it did for @mongoose and @mschelter two weeks ago), and seems to restart with Reboot reason: 0x13:
CNFG: Load online user config state change to 7
CNFG: Configuring LoRa module
LORA: Changing state from 2 to 4
LORA: Starting reconfiguration
LORA: version: 01
LORA: version: 01
MON: heap usage: 151KB (233KB), free: 188KB
LORA: version: 01
LORA: RESET MODULE
LORA: ChaSNTP: State change from 0 to 0
Click for full log
* The Things Network *
* G A T E W A Y *
Firmware name: AmazingAckermann, type: 0, version: 1.0.0, commit: 917719b9, timestamp: 1498499973
Bootloader revision: 1, commit: 7167873a, timestamp: 1496411298
Build time: Jun 26 2017 19:59:53
Reboot reason: 0x13
BOOT: (persisted info) 6F 72 72 65 01 03 83 2C E7 16 05 49 92 3A 54 B7
WIFI: Entering state 0
WIFI: Entering SCAN state 0
MAIN: Initialisation complete
LORA: Changing state from 0 to 0
MAIN: Leaving state 0
MAIN: Entering state 1
FLASH: Magic bytes found: wifi config present
FLASH: Magic bytes found: activation data present
FLASH: Magic bytes not found: no stored FOTA data present
FLASH: Loading Firmware Data
CNFG: (Firmware HASH (sha256)) FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FLASH: Loading WiFi Data
CNFG: WiFi SSID: redacted
CNFG: WiFi key: redacted
CNFG: WiFi conn_type: 1
CNFG: WiFi sec_type: 4
FLASH: Loading Activation Data
CNFG: Gateway ID: arjanvanb-gw-1
CNFG: Gateway Key: ttn-account-v2.W4...redacted...GLyDA
CNFG: Account Server URL: https://account.thethingsnetwork.org
CNFG: Locked: true
CNFG: Locked first time: false
MAIN: Leaving state 1
MAIN: Entering state 2
INET: State change to 0
LORA: Initialisation complete
LORA: Changing state from 0 to 1
WIFI: Entering state 1
ETH: IP Address: 0.0.0.0
WIFI: Entering state 4
WIFI: Entering SCAN state 1
SNTP: State change from 0 to 1
Scan is completed successfully
WIFI: Entering SCAN state 2
WIFI: Entering SCAN state 5
WIFI: Entering state 2
WIFI: Disabling modules
Head magic match void: trying to free an already freed block, ignore
SNTP: State change from 1 to 1
WIFI: Entering state 3
WIFI: Enabling modules for client
WIFI: Entering state 6
>WIFI: IP Address: 0.0.0.0
CB: INET: Gateway has WiFi
INET: State change to 2
INET: Connected to a network, waiting for DHCP lease, checking validity with ping
SNTP: State change from 1 to 2
WIFI: IP Address: 192.168.178.53
LORA: Wait init complete, waiting for application.
LORA: Changing state from 1 to 2
MON: SYS Stack size: 3961
MON: heap usage: 147KB (156KB), free: 192KB
INET: State change to 3
INET: Ping probe
INET: Error sending probe on Eth
INET: Ping response from MRF24WN, set as default
INET: State change to 4
SNTP: State change from 2 to 3
SNTP: State change from 3 to 4
SNTP: State change from 4 to 5
SNTP: State change from 5 to 6
SNTP: State change from 6 to 7
INET: State change to 5
MAIN: Leaving state 2
MAIN: Entering state 3
CNFG: Load online user config state change to 4
HTTP: Close active socket 0
HTTP: Got 1280 bytes
CONF: Parsing response token: HTTP/1.1 200 OK
CONF: ROUTER URL: mqtts://bridge.eu.thethings.network:8883
LORA: version: 01
LORA: version: 01
LORA: version: 01
LORA: RESET MODULE
TTN Console shows:
Before this loop, I easily got to Step 2 “Connect” and moved on to Step 3, “Configure” while still connected to gateway’s AP. Next, when connected to the internet again in Step 4, “First message” the LEDs loop until 3 continous lights (“Activated”) and I see some LEDs flashing on the LoRaWAN board. I’ve repeated a few times by holding down the reset button while powering up.
…@rish, but Step 3 needs this connection, doesn’t it? So, one should only connect to the internet after Step 3?
Did you do all that by only removing the white cover, or did you also remove part of the black casing?
Any specific place or direction to apply that force?
In my case http://things-gateway/info is accessible on my WiFi network and says Gateway Card: 868Mhz and I see LEDs flashing, so it’s surely (partly) connected.
