My guess is that the resistor is actually not functional, but rather just being used as a machine-installed marker of build version.
I’m also not entirely convinced that a US915 build would fail to start the concentrator with EU833 settings - it’s not like the Semtech silicon knows what the surrounding passive components are tuned for. In theory there could be an IO pin read somewhere by software or FPGA code that throws an error, but it’s not clear it is that smart.
And even in the unlikely case where the resistor is what is preventing it from trying to work on EU frequencies, just moving that wouldn’t change that all of the RF network are tuned for 915 instead of 868 - those aren’t something you can casually change without a full understanding of the design and a stock of the right parts. So even if it started, at best it would work poorly.
Getting shipped the wrong version is of course a problem; but it may not only be the wrong version, but a defective unit.
the us Version of TTIG automagically will Load US frequency Plans, when starting. So it never can be used in OLD EUROPE… Btw they also sent ME a wrong US Version…
Ok, yesterday morning I voided my warranty. Since pictures of the open patient have been already published, I add only a detail abot where i have put the antenna connector:
RS USA (Allied Electronics & Automation) has begun shipping USA orders. My TTIG ordered 3/13 was mailed last night from Ft. Worth, TX and is scheduled to be delivered tomorrow.
Mine arrived in Boston today! Just got one connected and successfully passing some data using the instructions: https://www.thethingsnetwork.org/docs/gateways/thethingsindoor/
(the EUI for me started with 58 rather than 5B… I can have trouble distinguishing them in tiny type)
I had now the TTIG for a while and can now compare it with a RAK2245.
I realize, as many above that the TTIG is missing a lot of packets, and does not work with some of the channels. Is this problem solved ?
What is the way to update the firmware, and what is the current firmware ?
Mine is :
I too found that some packets get lost. Packets I know of because received by 2-3 gateways at distance (10-20km, not mine).
My impression, formed initially when I observed with some attention the gateway log in the console, is that the gateway is like deaf for some time after receiving a packet. This in part could be due to downlinks windows, but I did not check whether downlinks were sent too in those moments.
Interesting - a test to run could be to blast out two packets in quick succession, that aren’t actually from any recognized node (and therefore won’t generate any downlink reply) and see if they get reported as raw gateway traffic.
Hi guys. Recently received the TTIG. Works like a charm. But… no power plug in the package from RS Components. Was really hoping to get one afterwards…
