TTIG AU915 support
Adding my TTIG to the request queue as well please
eui-58a0cbfffe8018ae
The 5 gateways in this thread are now configured. Please power cycle your gateways or wait for the automatic 24 hour connection to the configuration server.
Thanks,
Krishna
Yay! Traffic!
Thank you again @KrishnaIyerEaswaran2 for your help!
Awesome, all working for me thanks!
Ooh. Yes, please
eui-58a0cbfffe8025b1
eui-58a0cbfffe802cb0
Both @digs and @nowiresfil are done :white_check_mark:
Hi Krishna
Any chance you could add my gateway?
eui-58a0cbfffe802596
Also :white_check_mark:
Can you please add the following TTIG?
  • eui-58a0cbfffe8024f6
  • eui-58a0cbfffe80263b
  • eui-58a0cbfffe802d20
Many thanks in advance
Done :white_check_mark:
Hi Krishna
All my TTIG showing solid green
but it in the TTN console showing not connected
i can only see connected when power cycle the TTIG for few min
Status: not connected
Frequency Plan: Australia 915MHz
Router: meshed-router
please let me know if i have to do something?
Hi. Have you checked out this thread TTN Console not working properly all the time [console] [gateway] [not connected] [no traffic] [application] [no data]
Whilst you gw May show not connected can you still see traffic coming in from your nodes to your Applications?
If yes but in area where you know there may be coverage from other nodes check in the message metadata to see if your troublesome gw(s) are amongst the ones passing on the message. If they are not there then it may be (and likely is) the case that they are not connected and you have more troubleshooting to do or need Krishna’s help…
Can I get my gateway added please? eui-58a0cbfffe80251e
Thank you.
I found I was still having problems connecting, but at least I knew my gateway is now working.
I located a great post from Thomas Laurenson which got my project up and running.
Many Thanks
And to everyone else, please keep this thread specifically for requests to route gateways to the AU Cluster. For issues for TTIG connectivity, there are quite many other threads. Thanks :+1:
Could you please add this one too? eui-58a0cbfffe802c5c
Tks
Hello there @KrishnaIyerEaswaran2 !
I have recently purchased a TTIG AU915 for Posadas and I am facing troubles with OTAA using my LoPy4.
I can confirm the code on my LoPy4 works fine because I have tested it against my Dragino LG308 and it successfully joins TTN.
However, when I try the same code against my freshly unboxed and configured TTIG-AU915 it does not even receive the activation message.
In order to make sure that the device is operating within the right frequencies, I uploaded on purpose a new code to my node, but this time using the US915 plan. Surprisingly, I see activation messages being prompted on the console that are arriving on an unexpected frequency (904.6 MHz) see screenshot below
Screen Shot 2020-12-18 at 15.42.52
I am quite confused tbh. From what my tests yield, it seems like the TTIG-AU915 is not really listening to the right sub band for Australia, but for the US although the label on the device states “For AU & NZ”.
IMG_5891
Any help here will be highly appreciated.
Best regards,
Milton
Can you also please add mine? eui-58a0cbfffe8030bd
Mi user is: https://www.thethingsnetwork.org/u/snorkman
Thanks.
@snorkman: Done :white_check_mark:
