Hi there, I’ve been trying to get my ttgo t-beam v0.7 node working (two button model) but after several attempts and sketches the TTN console still shows as ‘unseen’.
I have starting with the ttn-abp.ino sketch from the arduino-lmic example to get a “Hello World” message
Added my NWKSKEY, APPSKEY and DEVADDR from the TTN Console
Updated the Pin Mapping in the sketch which I believe corresponds to the T-BEAM v0.7
- Changed the IBM_LMIC_framework\src\lmic\Config.h - uncommented us915 1 (I’m in Australia)
//#define CFG_eu868 1
#define CFG_us915 1
- Completed the steps posted by Zodiac here
- For the Physical setup on the TTGO, I have cable connecting LORA1 to Pin33.
The sketch compiles, and boot and after a while the GPS lit is blinking (GPS lock) and the Blue led is solid-on. Serial monitor when connected shows messages are sent.
There is no gateways near me, so I wardrive through an area that has a lot TTN gateways according to the TTN Map, with the hope of my message going out.
Any suggestions on what I’m missing?
Should there be a payload I need to enter in the console for the "hello world’ message?
Thanks in Advance.
