The Things Node - Central
Wondering if anyone can help. I recently tried to set up a things node but it would not connect to my universities gateway. The gateway is operational. I tried using older versions of the basic sketch but they did not work so I changed back to the most recent version. I then tried to update the firmware in my node using the guide:
but after the update when I upload the basic sketch the serial monitor stops after:
Light: 49
Temperature: 28.69 C
Temperature alert: No
Moving: No
Button pressed: No
Color: Black
USB connected: Yes
Battery voltage: 4724 MV
– TTN: STATUS
Does this mean I have bricked my node? I cannot find the node on the LoRaWAN development utility. I’m not sure what to do next
