That can be used to make a node only…e.g. a gps tracker, asset tracker or generic sensor but can’t be used as a gateway on TTN… you need a full 8 channel LoRaWAN NOT LoRa system. You can use your card for LoRa only, proprietary, e.g. point to point implementations…do not attempt to set up as a gateway and connect to TTN as they are disruptive to the network and other users. (Search Forum for SCPF of DCPF for discussions and explanations of why not).
Ok sir Thank you sir
For future ref please use search to find a topic suited to your issue/question or create a new one rather than hijacking an an existing, unrelated thread…and where there are responses to your earlier post please try to avoid deleting unless necessary as it leaves follow on comments potentially orphaned and nonsensical…
Ok sir
I forgot to migrate two of my (remote) devices. Is ther a possibility to download all configuration data from old v2 console? or is this too late as well?
Try the Take Out Tool…
I am all of the above!!
Off with COVID (fully jabbed I might add). So figured I’d put a bit more effort into finishing migration and tidying up my back end code (Node-Red).
Forgot about all the decoders! Horrible sinking feeling I was going to spend weeks not remembering which bits of code where Big Endian v Little Endian and world of other pain!!!
This just saved me weeks of work. Winner!
Thank you, this is awesome.
Jim
This update killed my node-red on 11 December. The ttn add in died and took node-red out. I was unable to upgrade TTN from V2 to V3 as there was zero support for us poor people outside of Europe. The upgrade tool did not work with AUS 925 MHz and despite numerous messages on this forum no-one provided any information. I gave up and abandonded my lora gateway (after almost 4 years) which was sad but with no support what else could I do. I was getting up to 2M messages a month so assume people in the community around me have also noticed it has gone.
The only support channel for community users was this forum - we all had equal access.
You don’t appear to have posted in the last six months, much has changed & been updated in that time.
If you leave your gateway turned on it will continue to work and continue to server the people around you. And gateway migration, in theory, is relatively simple compared to moving some devices.
Perhaps you could re-evaluate the situation?
