I close this topic.
please use #ops in Slack voor network connection problems.
’ Posting gateway EUI’s in this thread does not have any added value because this topic is not monitored by TTI staff. Adding EUI was also not suggested in the topic start.
We have 3 gateways in Danang city (Vietnam) that have been working for a while (several last months) without any problem.
However, since Sunday or Monday the status of all the gateways in TTN turned to “not connected”.
We have 4 end-nodes connected to this gateways and Lora traffic is being send normally as before. We have tried to reset the gateways but the problem is still there. We then tried to change the Router id from “ttn-router-asia-se” to other router but it did not help.
I’ve recently updated a v1 TTN gateway to firmware 1.0.5 using an SD card. It was previously displaying the constant reboot issue.
The update seemed to work, I could activate the gateway and see it’s status as connected in the TTN console.
I set up an application and registered a Laird RS186 OTAA device, but the gateway console never displays any traffic,such as join request/accept frames. The gateway overview shows Received/Transmitted messages as 0. The OTAA device has never been seen.
I captured some serial info from the gateway which suggests it is seeing the LoRaWAN packets and sending them up via MQTT to the router url mqtts://bridge.eu.thethings.network:8882
The local gateway info page at http://things-gateway.local/info shows that the gateway believes it has sent packets up with a true connection to the broker.
I know the Laird device works as I’ve used it on different LoRa servers. I also tried an old Semtech LoRa Mote which also works, but also does not show as traffic on the console.
Any assistance would be greatly appreciated if anyone has seen this behaviour. Should the traffic page on the console show all LoRaWAN packets seen by the gateway?
my Draguino Gateway that has been working for months is showing that it hasn’t been connected for 11 days, but data is coming thru for the nodes connected to it.
I also have a RAK831 gateway with the same issue.
What’s going on?
MultiTech Conduit V1.4.17
Brand new installation (my first gateway)
Showed up as Connected for the first 2 days and received plenty of packets.
Then suddenly, for no apparent reason, shows up as disconnected.
However, packets are still getting through to TTN, although I only tested with ABP uplink, no downlink.
I can see the data arrive at TTN Console -> Application Data.
Looking at TTN Console -> Gateway Overview the “Received Messages” counter does NOT change, even when a packet is getting through.
Here is what I’ve tried so far:
changed router from ttn-router-asia-se to thethings.meshed.com.au
reboot, power down, multiple times.
upgraded firmware from 1.4.16 -> 1.4.17
reinstall TTN packet forwarder.
leave power off for 12hrs
As far as I can see, this problem appears to be on the TTN end, not the gateway end.
Any suggestions or further debugging instructions would be very much appreciated.
I’m having similar issues with my Multitech Conduit gateways, as they are all ‘disconnected’.
After reconfiguring multiple times and trying different AEP firmware versions, I got one to forward the data to TTN, even though it was still listed as offline. However, it has stopped working altogether since last week again.
I’m in Eindhoven, Netherlands and using the ttn-router-eu.
