Intel Neural Compute Stick 2
- https://www.geeky-gadgets.com/intel-neural-compute-stick-2-unveiled-at-intel-ai-devcon-14-11-2018/
- https://www.techspot.com/news/77420-intel-announces-neural-compute-stick-2-deep-learning.html
rotary phone into a virtual assistant
I think that would fit nicely on the new wifi only RPI 3 A+ for an extra small gw ?
Azure IoT Central Device Bridge
This repository contains everything you need create a device bridge to connect other IoT clouds such as Sigfox, Particle, and The Things Network (TTN) to IoT Central. The device bridge forwards the messages your devices send to other clouds to your IoT Central app. In your IoT Central app, you can build rules and run analytics on that data, create workflows in Microsoft Flow and Azure Logic apps, export that data, and much more. This solution will provision several Azure resources into your Azure subscription that work together to transform and forward device messages through a webhook integration in Azure Functions.
Starlink 12K: Elon Musk’s Big Gamble on Global Satellite Internet
SpaceX CEO Elon Musk’s plan to provide high-speed communications to virtually any location on Earth got a big boost this week when the Federal Communications Commission (FCC) approved the company’s plan to add 7,518 satellites to the company’s Starlink constellation.
first 5G customer trial deployment in South Africa
MTN South Africa and Ericsson (NASDAQ: ERIC) have announced the first 5G customer trial deployment in South Africa starting with a fixed wireless access site at technology company Netstar’s headquarters in Midrand.
Coming Soon NeroNode-Mini. Based on arduino architecture, This development board is both Lorawan and Sigfox compatible with protection on all I/O lines and on-board solid-state Memory, RTC and Vibration sensor. Actual size 50x50x20mm
an operating system kernel is really just a very powerful shared library - Red Hat Unikernals
