The LIBRARY basement part 5
GNSS IoT Positioning: From Conventional Sensors to a Cloud-Based Solution
’ why is it so yellow in here ? ’
By default, the Node-RED editor is not secured - anyone who can access the IP address and port it is running on can access the editor and deploy changes. This is only suitable if you are running on a trusted network.
This section describes how you can secure Node-RED.
Ultra-Small Integrated AFE for Wearable, Optical Heart-Rate Monitoring and Biosensing
The AFE4404 is an analog front-end (AFE) for optical bio-sensing applications, such as heart-rate monitoring (HRM) and saturation of peripheral capillary oxygen (SpO2).
The device supports three switching light-emitting diodes (LEDs) and a single photodiode.
The current from the photodiode is converted into voltage by the transimpedance amplifier (TIA) and digitized using an analog-to-digital converter (ADC).
The ADC code can be read out using an I2C interface. The AFE also has a fully-integrated LED driver with a 6-bit current control.
The device has a high dynamic range transmit and receive circuitry that helps with the sensing of very small signal levels
connect your Raspberry Pi to a Bluetooth OBD-II adapter and display real-time engine data
283160-DC%20Press%20Release5-fc3ff0-original-1529048797
Amsterdam, 18 June 2018Digital Catapult’s Things Connected initiative has partnered with The Things Network (TTN).
ttn-nyc
LoRa%20Alliance%20award
OCT 4 - The Official Things Network On Tour Conference - Slovenia, Maribor
OCT 15 - The Official Things Network On Tour Conference - Norwich, UK
LoRa/LoRaWAN ‘Mass adoption’ per Semtech’s Pegulu’s LoRa Alliance Vancover pitch
like the EU … but they lie about it and that system can listen to a conversation IN your car !
