Tired of chasing escaped livestock due to electric fence failure? Wait no more! LoFence is a #LoRaWAN capable #IoT electric fence monitoring system running on #TTN
Semtech Releases Reference Kit to Simplify Development of LoRa®-based Smart Building Solutions
Self-contained kit enables quick set-up and management of smart building solutions to extend/expand Internet of Things to a wider audience
cool ! a collectors item
TheThingsNetwork Kiel
*Today we exchanged the antenna of the #LoRaWAN gateway in #Kiel *
Now the 5 dBi antenna from @RAKwireless is running (thinner right antenna in the picture).
Sheesh, 1TB.
The first ‘computer’ I built had 256bytes of RAM with a further 128byte ‘upgrade’
Static Context Header Compression
*Passing LoRaWAN test logs for open-source Arduino-LMIC! Code at https://mcci.io/lmic-code . *
Passing as a Class A 1.0.3 device, for KR-920 region, test spec V1.2.
Test device: Adafruit Feather M0. Thanks to @redwoodcomm for great tester.
Code pushed on branch issue87-devel.
