The BIG and SMALL ANTENNA topic part 1
I’m using the default antenna that came with the gateway, it’s inside about 4 meters high under the rooftop.
Are you getting good coverage from this? I have several roof-space mounted GW’s around the country (including a bunch of the Lairds) and in each case I have had to be careful with placement due to various roof constructions, especially in modern or recently refurbished buildings.
Often the roof itself will be heavily lined with thermal insulation that these days is increasingly made with an additional layer of metal foil - a great RF blocker!..sometimes several layers. (Foil backed plaster-board/dry-lining increasingly common also). The foil doesn’t just ‘block’ but if too close to ant seems to help ‘detune’ also. In other instances have discovered a layer of mineral loaded water resistant ‘felt’ to ensure good weather proofing - again some of these materials appear to badly affect rf propagation. In these cases have found that rather than going to the highest roof point assuming height = better range, have found dropping to attic floor level has actually increased range as signal ingress/egress under insulation better.
Best yet a small hole under the eves, later closed to stop insect ingress, allowing use of external antenna on short run of ultra low loss feed cable usually works wonders (typically 10-30db signal improvement :slight_smile: ) :wink:
There’s actually no insulation besides the asbestos roofing… Don’t know if that blocks the signal.
I’m going to put an antenna on the roof anyway, but if i’m going to spend money on that i 'd rather buy a good one.
With these 2 options:
I think the GP901C is the better one? There’s also a GP868C, wouldn’t that outperform the GP901C?
The GP901 C has a Frequency Band of 870-960 MHz where the GP868 C has 835-900 MHz.
I think the GP868 is better suited for Lora in Europe.
Yes, if you have managed to increase c - you’d better prepare the universe :slight_smile: What link of Fabiens are you referring to exactly? I’m trying to gain access to a radio lab here over the student holiday period. Annoyingly we did just build an array which was incredible at about 550M and then we scaled it to 868MHz - I’ve lost the paperwork but the unit is up on the roof. @loratracker has achieved some remarkable results too (but is currently side-tacked, deep in a local, (unused), railway tunnel proving that the Semtech chip has a noise issue).
Here is the link to the two different designs. its on the IRNAS GitHub site https://github.com/IRNAS/ttn-irnas-gw
@dicktonyboy, hope you can find the paperwork for the converted 550M antenna. Guess you’ll be shimmying up a drain pipe to measure. :joy: Over the weekend I will also try a Coaxial Colinear, bit fiddly to build but hope the VSWR match is better than the 2:1 in Fabien’s modelling work. If it looks promising, I’ll test the gain and pattern.
So a question for @BoRRoZ and @Charles to see how you guys found the Rak antenna, the fiberglass one you both ordered and discussed in the bargain basement thread?
I hope to deploy some more gateways using @Charles’s pcb to integrate Rak831’s with Pi Zeros. I ordered an antenna with some Rak831’s so would be interested in data on tuning or performance?
Thanks gentlemen!
Garry
https://m.aliexpress.com/item/32852314761.html?trace=storeDetail2msiteDetail
I just received one last week but I haven’t done any testing yet…
My gateways have SMA pigtails and the RAK antenna is delivered with an RP-SMA connector, so I need some additional bits to swap easily…
I found some bits… :wink:
dbisetup
will try to test (again) today (weekend :roll_eyes:), last time all the graphs went wrong
Just installing the Siro GP868 C this week, very well built piece of kit
@dicktonyboy. Just built an 868 MHz colinear antenna to compare with the modelling you posted. Get the exact same shape VSWR curve as per the simulation. Min VSWR is 2.1 but instead of it being around 860-870MHz mine has a minima at 840 MHz. Followed the Tips and could not change the resonant frequency by changing the size of the “last loop”. By that I assume the top loop. Going to see if the “last loop” is the bottom loop which I expect will change the resonant frequency. Just going to solder a “shorting link” to bypass some of the loop and adjust its position to tune to the required frequency.
Hi All,
As winter sets in in Australia I have been noticing my receive levels going down, from RSSI’s of 76 to now 88, very confusing. I pulled down my colinear 915Mhz antenna and found it was full of water. As you will notice from the picture the antenna is housed in a high pressure PVC pipe with caps at either end. I cant work out where the water got in.
How do others seal their antennas? What is best practice?
Chris
IMG_1455
@cdann, are the pvc pipe caps solvent welded to the tube or just press fitted? Also, how does the cable enter, via a compression gland? Are there any other penetrations, eg for radials etc. I always recommend using self vulcanising / self amalgamating tape on antenna connectors to form a water tight seal. You can use the same tape to seal between the PVC pipe and the antenna cable where the cable enters the tube. Bunnings sell this as a Silicon Self-Fusing tape. If you post some close up photos of the penetrations into the PVC tube, we may be able to provide more detailed answer.
Test results are in. Obtained a VSWR of 1.2:1 and was able to tune the antenna very easily. Its a coaxial dipole consisting of quarter wavelength at the bottom, followed by 8 half wavelength sections stacked above. Built from RG58CU I assumed a Velocity Factor of 0.66. Tuned by trimming the top half wavelength piece of coaxcoax_colinear Next step is to check its gain but I expect it will be 6 or so dBi.
Did you also use radials as groundplane? I remember somebody else built a similar antenna but with 4 radials.
Hi Tony,
Thanks for your rapid response. No due to the ongoing changes I have not welded anything at this point. The only penetration is for the n-type connector located on the bottom of the antenna. It is a snug fit. It did not seem necessary to do more than press fit, clearly I was wrong. I have attached some closeup pictures. Thanks for your advise on silicon tape.
Chris
IMG_1456IMG_1457IMG_1460IMG_1461
its common for water to enter a Waterproof enclosure, even one with rubber seals. As the enclosure heats and cools the air pressure inside raises and lowers. If the seal is not strong enough the drop in air pressure will suck air past the seal and any water sitting on the seal will be sucked in. it effectively pumps water into the enclosure. I suspect water sitting on the bottom fitting (which is not glued) is being sucked inside the tube. You could solvent weld this joint and leave the top one loose. There is another option and that’s to glue the top cap and put a pair of threaded fittings between the bottom of the pipe and the bottom cap, this would give you access to the bottom of the pipe again. Just seal the threads with plumbers tape. I would also apply self sealing tape around the bottom of the pipe and wind it all the way over the connectors all the way to the coax cable. I’d also suggest you don’t use small coax outside as its hard to apply tape around such a small diameter. Use a larger diameter coax with N-Type connectors and make the N-Type to SMA conversion at the back of the gateway board with a short (100mm tail) Large diameter coax will also have lower losses.
Hope this helps
Yes, 4 radials at 1/4 wavelength. since there is no dielectric on the radials the velocity factor = 1. they are also horizontal, no need to downtilt at 45 degrees.
Any building process photo?
