The BARGAIN basement part 4
€ 5,91 + € 2,00
gluegun
needletip
1000V 20A Super Thin Tip Needle Multi Meter Test Probes - US $2.99 incl.shipping
icstation17-8
-15 % last day NL
superbat2
nl
ideal for backplates :sunglasses:
US $2.49 incl. shipping
t-beam
tip from @Linar
US $1.62 incl. shipping
US $3.75 incl. shipping
I like those tiny boxes with separately covered compartments to organise my little hardware nuts and bolts - the default one you find with only slide-in separators between compartments always ends up making a mix-mess when you carry them around.
$ 0.97 each
Made a short current measurement on the BME280 breakout boards (4-Pin vs 6-Pin), the 4-Pin has a voltage regulator on board and therefore uses much more current. Of course the regulator can be removed.
Stock 4-pin breakout: 7.66ua in sleep mode
Stock 6-pin breakout: 0.173ua in sleep mode
More informations: https://it-net.blog/?p=148&lang=en
4-Pin breakout: https://www.aliexpress.com/item//32665342978.html
6-Pin breakout: https://www.aliexpress.com/item//32685226498.html
Hope this information is useful for someone.
M3%20Hex%20Socket%20Cap
eBay
Wind%20Speed%20Sensor
