The BARGAIN basement part 1
I’m always a bit scared, usually it’ll cost me money…
Semtech SX1301 concentrator chips $2.50 :slight_smile:
https://world.taobao.com/item/535962847954.htm?spm=a312a.7700714.0.0.s0Atsa#detail
Anyone up to build a cheap gateway?
and the SX1257 ??
SX1257 is also available for about the same:
https://world.taobao.com/item/536958313984.htm
But Mouser, Digikey etc has the SX1257 too…
we will see a big change in the market…
I can imagine we’ll see open source hardware LoRa gateways popping up on github… here’s one to get started:
other relais boards
If anyone is curious what 10x SX1301 chips look like as sent by an Ali seller :wink:
(and 10x SX1257 and 10x SX1276)
did you really buy those? Are that the 2,50 chips? I assumed someone made a typo…
the real deal :yum:
Yes, that’s a real photo of the chips I bought from the link above. $2.45/each for the SX1301 and SX1257, $1.30 for the SX1276
Photo was taken at my Hong Kong fulfilment centre - perks of running a shop - I should have them in my hands in about a week for full analysis, hopefully first test PCB will be here too.
have to be carefull searching for the sx1301 on AliExpress thats a whole different chip :sunglasses:
https://maxict.nl/product/2681360/tp-link-poe-adapter-kit?btwview=in&rs=tweakers&utm_source=tweakers&utm_medium=cpc&utm_campaign=pricewatch
This Power over Ethernet kit will power devices over an ethernet cable up to 100m and its only ~18,50 euro. It has a injector and a splitter. PoE runs at 48V and i havent measured any voltage drops so far. A toggle on the splitter will allow you to switch the output DC between 5V/2A … 9V/1A … 12V/1A.
Tested and works with a Raspberry PI 3B in combination with a IC880A IMSI Concentrator board
Hopefully the TTN GW’s are in that same power range … will save a lot on cabling :slight_smile:
