node/base antenna
update : short cable if you mount something close to the antenna
node/base antenna
hey hey, excellent
2.5 meter of cable, looks great
dBi not indicated, is it better than this 5 dBi one ?
http://www.rocketscream.com/blog/product/868-mhz-5-dbi-dipole-antenna/
it’s 3 dbi , but better suitable for outdoor use ( stainless) and comes with cable and mounting bracket.
and here you’ll find material to mount your antenna : http://www.antennebeugel.nl/index.php
@BoRRoZ
Oh, I thought the one you presented was better or at least equivalent because you’re right perfect for outdoor
I’m waiting for my https://www.aerial.net/shop/product/39/1102/ezynet-outdoor-enclosure-1-ethernet.html
You have a good distance with this antenna?
@hugomartins
I’ll do some test as soon as I put my gateway on the roof
Ok, with my antenna i dont have a very good performance, i expected more.
I think this antenna is normal, i need buy a 5dB antenna to try increase the distance/sensibility. And a SMA cable to put the antenna outside of the box,
868 MHz fiberglass base antennes
6 dbi € 35,71
6.5 dbi € 35,33
8 dbi € 43,06 —> NOW € 40,43
12 dbi € 50,78
14 dbi € 47,55
You have tested this antennas in the gateway?
Can you give us your feedback about tested distances?
There is any limit of antenna dB can use in the gateway?
I read somewhere that the max antenna dB can use in gateway Lora is 5dB
sorry, this is the bargain basement and maybe its better to start a separate ‘antenna’ topic
update
today arrived my order… from germany, I didn’t expect topquality but I was positively supprised what you get for 8 euro’s including shipping
2.4" NX322K024 'enhanced LCD touchscreen
Nextion LCD TFT HMI Display allows you to design your own interfaces all by yourself, even if you don’t have any coding background knowledge. It can work with Arduino, Raspberry Pi, Raspberry Pi A+, B+ as well as Raspberry Pi 2/3.
onderdelen nodig maar geen FARNELL business account ? --> http://onderdelen.muxtronics.nl/
werkt geweldig en slechts 2 euro toeslag, geen minimum bedrag en geen verzendkosten !!
een paar SMD componentjes nodig, bestel online --> http://smdshop.nl/index.php
