Are you seeing node traffic comming through ok (check message metadata to see if your GW is listed as one of the ones passing messages through)…if so your GW is functining ok and you may be a victim of:
If no traffic then you may need TTN staff to enabe your specific EUI as above in the basic station bridge handler.
