Thank you so much for your help. I have the following info:
Click to see the code
```cpp
- Copytight © 2016 Maarten Westenberg based on work of
- Thomas Telkamp and Matthijs Kooijman porting the LMIC stack to Arduino IDE
- and Gerben den Hartog for his tiny stack implementation with the AES library
- that we used in the LMIC stack.
- Permission is hereby granted, free of charge, to anyone
- obtaining a copy of this document and accompanying files,
- to do whatever they want with them without any restriction,
- including, but not limited to, copying, modification and redistribution.
- NO WARRANTY OF ANY KIND IS PROVIDED.
- This example sends a valid LoRaWAN packet with sensor values read.
- If no sensor is connected the payload is ‘{“Hello”:“World”}’, that
- will be processed by The Things Network server.
- Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in g1,
- 0.1% in g2).
- Change DevAddr to a unique address for your node
- See http://thethingsnetwork.org/wiki/AddressSpace
- Do not forget to define the radio type correctly in config.h, default is:
#define CFG_sx1272_radio 1
- for SX1272 and RFM92, but change to:
#define CFG_sx1276_radio 1
- for SX1276 and RFM95.
#define WAIT_SECS 120
#if defined(AVR)
#include <avr/pgmspace.h>
#include <Arduino.h>
#elif defined(ARDUINO_ARCH_ESP8266)
#include <ESP.h>
#elif defined(MKL26Z64)
#else
#error Unknown architecture in aes.cpp
#endif
#include “lmic.h”
#include “hal/hal.h”
#include <SPI.h>
#include <RH_RF95.h>
// Sensor declarations
// Frame Counter
int count=0;
// LoRaWAN Application identifier (AppEUI)
// Not used in this example
static const u1_t APPEUI[8] PROGMEM = { 0x41, 0x8F, 0x01, 0xD0, 0x7E, 0xD5, 0xB3, 0x70 };
// LoRaWAN DevEUI, unique device ID (LSBF)
static const u1_t DEVEUI[8] PROGMEM = {xxxx };
// LoRaWAN NwkSKey, network session key
// Use this key for The Things Network
unsigned char NwkSkey[16] = { xxxxxxxxx };
// LoRaWAN AppSKey, application session key
// Use this key to get your data decrypted by The Things Network
unsigned char AppSkey[16] = { xxxxxxx };
// LoRaWAN end-device address (DevAddr)
// See http://thethingsnetwork.org/wiki/AddressSpace
#define msbf4_read§ (u4_t)((u4_t)§[0]<<24 | (u4_t)§[1]<<16 | §[2]<<8 | §[3])
unsigned char DevAddr[4] = { xxxxxxx };
// APPLICATION CALLBACKS
// provide application router ID (8 bytes, LSBF)
void os_getArtEui (u1_t* buf) {
memcpy(buf, APPEUI, 8);
// provide device ID (8 bytes, LSBF)
memcpy(buf, DEVEUI, 8);
// provide device key (16 bytes)
memcpy(buf, NwkSkey, 16);
int debug=1;
uint8_t mydata[64];
static osjob_t sendjob;
// Pin mapping
// These settings should be set to the GPIO pins of the device
// you want to run the LMIC stack on.
lmic_pinmap pins = {
.nss = 10, // Connected to pin D 15
.rxtx = 0, // 0
.rst = 9, // Needed on RFM92/RFM95? (probably not) D0/GPIO16
.dio = {2, 6, 7}, // Specify pin numbers for DIO0, 1, 2
// connected to D5, D4, D3
void onEvent (ev_t ev) {
//debug_event(ev);
switch(ev) {
// scheduled data sent (optionally data received)
// note: this includes the receive window!
case EV_TXCOMPLETE:
// use this event to keep track of actual transmissions
Serial.print("EV_TXCOMPLETE, time: ");
Serial.println(millis() / 1000);
if(LMIC.dataLen) { // data received in rx slot after tx
//debug_buf(LMIC.frame+LMIC.dataBeg, LMIC.dataLen);
Serial.println("Data Received");
break;
default:
break;
void do_send(osjob_t* j){
delay(1); // XXX delay is added for Serial
Serial.print("Time: ");
// Show TX channel (channel numbers are local to LMIC)
Serial.print("Send, txCnhl: ");
Serial.println(LMIC.txChnl);
Serial.print("Opmode check: ");
if (LMIC.opmode & (1 << 7)) {
Serial.println(“OP_TXRXPEND, not sending”);
else {
strcpy((char *) mydata,"{\"Hello\":\"World\"}");
Serial.print("ready to send: ");
Serial.println((char *)mydata);
LMIC_setTxData2(1, mydata, strlen((char *)mydata), 0);
// Schedule a timed job to run at the given timestamp (absolute system time)
os_setTimedCallback(j, os_getTime()+sec2osticks(WAIT_SECS), do_send);
// SETUP
void setup() {
Serial.begin(115200);
// LMIC init
os_init();
LMIC_reset();
// Set static session parameters. Instead of dynamically establishing a session
// by joining the network, precomputed session parameters are be provided.
LMIC_setSession (0x1, msbf4_read(DevAddr), (uint8_t*)NwkSkey, (uint8_t*)AppSkey);
// Disable data rate adaptation
LMIC_setAdrMode(0);
// Disable link check validation
LMIC_setLinkCheckMode(0);
// Disable beacon tracking
LMIC_disableTracking ();
// Stop listening for downstream data (periodical reception)
LMIC_stopPingable();
// Set data rate and transmit power (note: txpow seems to be ignored by the library)
LMIC_setDrTxpow(DR_SF7,14);
//Serial.flush();
Serial.print(F("A: ")); Serial.println(msbf4_read(DevAddr),HEX);
// LOOP
void loop() {
do_send(&sendjob);
while(1) {
os_runloop_once();
yield();
