Smart Garden Project Complete with Mobile App
MIT AppInventor is pretty simple to get started.
Thanks! I used Xamarin Forms for my mobile app, but that’s what I do for a living (mobile developer/designer). Otherwise, as descartes mentioned there are platforms that can get you started quickly.
i have same project but with little different idea but i dont know how can i add read value of the soil moisture to the TTN to manage and monitoring
can you help me please with steps in detail
respects
Hi Mateen,
That’s a bit of a vague question. In short, you need to
  1. Read a soil moisture sensor via microcontroller
  2. Transmit the data over LoRaWAN to a TTN Gateway
  3. Transmit the data from a TTN Gateway to a backend that can store/analyze the data
It’s a fairly involved process if you’re starting from scratch, but there are plenty of examples online that can help with each step in that process.
thank you
but i dont find any example start from scratch to help me
i use node mcu8266 microcontroller and soil moisture sensor and temperature and humidity sensor and water pump
What LoRaWAN component do you use?
i dont use any LoRaWAN component and this is my code smart garden (2).txt (4.7 KB)
Sorry, but this forum is dedicated to LoRaWAN.
can you guide me to another free cloud not dedicated to specific type
You are using thinkspeak. Why don’t you use their Community?
It’s a great project. My project includes a raspberry pi 3, sense hat, 1-channel relay, and a 7" touchscreen.
Basically, it measures weather conditions, analyzes them, and sets nighttime irrigation through the relay depending on weather parameters and these water sprinklers. It’s got a web-accessible dashboard where the user can start the relay or reboot the system as well as see current weather conditions.
hi, did you get around to making the board design available to the public?
