Hi there,
Intro
I have a Dragino gateway (LPS8) and I am trying to make my Nucleo board (P-NUCLEO-LRWAN1) connect, using the default end-node code from STM32CubeExpansion_LRWAN_V2.0.0.
I keep getting rxTimeOut, and I am unsure why, perhaps I missed setting up something.
The questions
I tried changing the duty cycle from 10 to 30s, and OTAA to ABP. Neither seemed to help.
Does anyone know what it could be? I presume this is not expected behaviour, as I found a flag for rxDone in the code.
I think I might have missed some set up? Or is the gateway refusing to communicate?
Logs
Gateway setup
Gateway is connected to the TTN.
Logread RxTxJson
Sun Apr 25 08:49:29 2021 daemon.info lora_pkt_fwd[31113]: RXTX~ {"rxpk":[{"tmst":2880334028,"time":"2021-04-25T08:49:29.267227Z","chan":0,"rfch":1,"freq":868.100000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":9.2,"rssi":-53,"size":23,"data":"AAEBAQEBAQEBGGk2czAwMDk7iI5NlR8="}]}
Sun Apr 25 08:49:39 2021 daemon.info lora_pkt_fwd[31113]: RXTX~ {"rxpk":[{"tmst":2890379492,"time":"2021-04-25T08:49:39.311460Z","chan":1,"rfch":1,"freq":868.300000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":10.5,"rssi":-47,"size":23,"data":"AAEBAQEBAQEBGGk2czAwMDmvWkUJKEQ="}]}
FreqINFO:
Gateway Channels frequency
chan_multSF_0
Lora MAC, 125kHz, all SF, 868.1 MHz
chan_multSF_2
Lora MAC, 125kHz, all SF, 868.5 MHz
Logread REPORT:
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ ################## Report at: 2021-04-25 09:55:40 UTC ##################
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ ### [UPSTREAM] ###
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # RF packets received by concentrator: 3
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # RF packets forwarded: 3 (69 bytes)
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # PUSH_DATA datagrams sent: 3 (733 bytes)
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # PUSH_DATA acknowledged: 100.00%
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ ### [DOWNSTREAM] ###
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # PULL_DATA sent: 1 (100.00% acknowledged)
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # RF packets sent to concentrator: 0 (0 bytes)
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # TX errors: 0
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # TX rejected (collision packet): 0.00% (req:96, rej:0)
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # TX rejected (collision beacon): 0.00% (req:96, rej:0)
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # TX rejected (too late): 0.00% (req:96, rej:0)
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # TX rejected (too early): 39.58% (req:96, rej:38)
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # BEACON queued: 0
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # BEACON sent so far: 0
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # BEACON rejected: 0
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ ### [PPS] ###
Sun Apr 25 09:55:40 2021 daemon.info lora_pkt_fwd[31113]: REPORT~ # SX1301 time (PPS): 2534747127
The terminal
for OTAA
APP_VERSION: V1.0.0
MW_LORAWAN_VERSION: V2.2.1
MW_RADIO_VERSION: V0.0.1
###### OTAA ######
###### AppKey: 2B 7E 15 16 28 AE D2 A6 AB F7 15 88 09 CF 4F 3C
###### NwkKey: 2B 7E 15 16 28 AE D2 A6 AB F7 15 88 09 CF 4F 3C
###### ABP ######
###### AppSKey: 2B 7E 15 16 28 AE D2 A6 AB F7 15 88 09 CF 4F 3C
###### NwkSKey: 2B 7E 15 16 28 AE D2 A6 AB F7 15 88 09 CF 4F 3C
###### DevEui: 39-30-30-30-73-36-69-18
###### AppEui: 01-01-01-01-01-01-01-01
0s057:TX on freq 868100000 Hz at DR 0
1s581:MAC txDone
6s613:RX_1 on freq 868100000 Hz at DR 0
6s812:MAC rxTimeOut
7s613:RX_2 on freq 869525000 Hz at DR 0
7s812:MAC rxTimeOut
###### = JOIN FAILED
10s099:temp= 24
10s100:VDDA= 254
When Changed to ABP
###### = JOINED = ABP ======================
30s056:temp= 25
30s057:VDDA= 254
30s060:TX on freq 868500000 Hz at DR 0
30s068:SEND REQUEST
31s715:MAC txDone
32s748:RX_1 on freq 868500000 Hz at DR 0
32s947:MAC rxTimeOut
33s748:RX_2 on freq 869525000 Hz at DR 0
33s947:MAC rxTimeOut
###### ========== MCPS-Confirm =============
60s056:temp= 25
60s057:VDDA= 254
