Hi everyone,
I am using a single channel gateway using Heltec wireless shell and I used a DIY gateway code from github. The node is also using Heltec module and LMIC library.
The problem is my TTN console is displaying only 3rd consecutive data(Frame count: 2,5,8,11…). Can someone tell what is the reason?
Your node is sensing randomly on different frequencies while your single channel gateway only receives on one frequency. A single channel gateway is not LoRaWAN compliant. If you want to receive all messages you have to use a compliant gateway. Normally these gateways use 8 channels.
But I have enabled only one channel in my node
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// LoRaWAN NwkSKey, network session key
// This should be in big-endian (aka msb).
static const PROGMEM u1_t NWKSKEY[16] ={ Entered in actual code};
// LoRaWAN AppSKey, application session key
// This should also be in big-endian (aka msb).
static const u1_t PROGMEM APPSKEY[16] = { };
// LoRaWAN end-device address (DevAddr)
// See http://thethingsnetwork.org/wiki/AddressSpace
// The library converts the address to network byte order as needed, so this should be in big-endian (aka msb) too.
static const u4_t DEVADDR = ; // <-- Change this address for every node!
// These callbacks are only used in over-the-air activation, so they are
// left empty here (we cannot leave them out completely unless
// DISABLE_JOIN is set in arduino-lmic/project_config/lmic_project_config.h,
// otherwise the linker will complain).
void os_getArtEui (u1_t* buf) { }
void os_getDevEui (u1_t* buf) { }
void os_getDevKey (u1_t* buf) { }
static uint8_t mydata[]="Transmitting";
int count=0;
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 10;
// Pin mapping
// Adapted for Feather M0 per p.10 of [feather]
.nss = 18, // chip select on feather (rf95module) CS
.rxtx = LMIC_UNUSED_PIN,
.rst = 14, // reset pin
.dio = {26, 35 , 34}, // assumes external jumpers [feather_lora_jumper]
// DIO1 is on JP1-1: is io1 - we connect to GPO6
// DIO1 is on JP5-3: is D2 - we connect to GPO5
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
break;
case EV_BEACON_FOUND:
break;
case EV_BEACON_MISSED:
break;
case EV_BEACON_TRACKED:
break;
case EV_JOINING:
break;
case EV_JOINED:
break;
case EV_RFU1:
Serial.println(F("EV_RFU1"));
break;
case EV_JOIN_FAILED:
break;
case EV_REJOIN_FAILED:
break;
case EV_TXCOMPLETE:
if (LMIC.dataLen) {
Serial.println(LMIC.dataLen);
// Schedule next transmission
break;
case EV_LOST_TSYNC:
break;
case EV_RESET:
break;
case EV_RXCOMPLETE:
// data received in ping slot
break;
case EV_LINK_DEAD:
break;
case EV_LINK_ALIVE:
break;
case EV_SCAN_FOUND:
Serial.println(F("EV_SCAN_FOUND"));
break;
case EV_TXSTART:
break;
default:
break;
void do_send(osjob_t* j){
} else {
Serial.println("count:"+ String(count));
++count;
void setup() {
while (!Serial); // wait for Serial to be initialized
Serial.begin(115200);
delay(100); // per sample code on RF_95 test
SPI.begin(5,19,27);
os_init();
LMIC_reset();
// Set static session parameters. Instead of dynamically establishing a session
// by joining the network, precomputed session parameters are be provided.
#ifdef PROGMEM
uint8_t appskey[sizeof(APPSKEY)];
uint8_t nwkskey[sizeof(NWKSKEY)];
memcpy_P(appskey, APPSKEY, sizeof(APPSKEY));
memcpy_P(nwkskey, NWKSKEY, sizeof(NWKSKEY));
LMIC_setSession (0x13, DEVADDR, nwkskey, appskey);
#else
// If not running an AVR with PROGMEM, just use the arrays directly
LMIC_setSession (0x13, DEVADDR, NWKSKEY, APPSKEY);
#endif
#if defined(CFG_in866)
LMIC_enableChannel(2);
#elif defined(CFG_us915)
#endif
// Disable link check validation
LMIC_setLinkCheckMode(0);
LMIC.dn2Dr = DR_SF9;
// Set data rate and transmit power for uplink
LMIC_setDrTxpow(DR_SF9,20);
// Start job
do_send(&sendjob);
void loop() {
os_runloop_once();
Depending on single gateway code you must force you gateway to only receive on one channel. Some single channel has this . E.G enable channel 0 or you can disable all other channels. Note functions like ADR will not work
Also be careful where you operate your single channel packet forwarder, it can interfere with the operation of geniune compliant Gateways and nodes.
Almost, but not quite. Your code doesn’t add any additional TTN-specific channels, but then you’ll still have the 3 default channels. These are needed in each network for OTAA joins of LoRaWAN-compliant devices that need to know some basic settings that are generic for all networks.
I don’t see you disable the other two defaults anywhere. The following just enables a channel that is already enabled by default, but you’ll need a few LMIC_disableChannel
instead:
That’s also a problem of using a single-channel forwarder rather than a true gateway: nodes that are adjusted for such forwarder will often use one of the default channels, making those default channels being used far more often than the other channels a network might support.
Also, are you sure 20 is allowed in your region?
(For your next post please also see How do I format my forum post? [HowTo] And please add all details in your first post next time. Thanks.)
Thanks sir for your replay. After disabling the other channels ,it is working perfectly. I think 20 is accepted in India, but anyway I am just using this for testing. And next time I will take care of formatting
