Pq: database "ttn_lorawan" does not exist
I had read some of that, but not from the start so was missing a few things. I am not sure I understand your remark about DR0 & 1. I didn’t see this mentioned anywhere and by default the sensors we are getting do ADR on DR0.
Anybody got any solution to my original problem? Hopefully I’ll get a GW this PM so would love to get a server running by then.
Hi, I have the same problem as [flabrosse]
Hi, in docker-compose.yaml I changed :
image: thethingsnetwork/lorawan-stack:latest
with :
image: thethingsnetwork/lorawan-stack:3.18.0
and it worked
Yes it works! Thank you so much friend!
I just tried it, and it does indeed! How did you come up with this? Marking as solution.
Maybe this is a bug? Maybe the instructions need to be updated?
No problem ^^
Yeah it may be a bug, I came up with that because on docker-compose.yaml there is the link to the docker image of tts : Docker Hub and it was recently updated to 3.18.1 (6 days ago) and my previous installation worked fine before that update
