[PCB] Pro mini / RFM95W / 18650 solar chargeable
Hi Wijnand,
Do you still have a pcb’s available? If so, I would like to receive one
Kind regards,
I am also very interrested in such a board. Would you publish the schematics here or somwhere else?
Thomas
Hello.
I recieved fine PCB from @Wijnand.
A big THANK YOU!
Pictures follows.
Greets.
Hi @All
So i know @Wijnand would share his PCBs. He let us know: What's your experience with pcbs.io?
Something goes wrong with his account. I don`t know how to help. New owner of pcbs.io is https://www.makerbright.com/ ?
Is that the solution to get in contact to solve the problem?
Greets
I uploaded the design to pcbs.io again and that works.
Hey @Wijnand cool! :slight_smile:
Are you sharing? And show a link to the PCB?
Regards
For better use of the battery it could be used the MCP1700-300 (3 V output) or MCP1700-280 (2.8V output) to take into account the dropout voltage.
MCP1700 typical dropout voltage is 178 mV and maximum 350 mV at 25°C and load 250 mA.
Hello Mario
Great work!
One thing: I always try to avoid the linked battery holder in your blog, this spring version is very bad, maybe this is not a real issue at those low power applications, but the contact between the springs and the battery is very poor. I therefore always use some massive battery holders, like this one: https://www.aliexpress.com/item//32691749341.html
Where can we order the boards?
If you could share the files for the 3D case would be great! I could also print some if someone from Switzerland is interested in the case and doesn’t have a printer.
Thank you!
Hello my friend!
Theoretically, I can share the plans, but I’m currently working on version 2. This will be completely open hardware and so I can upload them on various platforms.
I hope you have a little patience;)
Is there anyone with experience with the CC1310? My new design (a VT-s02c module from Vincent Tang/China equipped with a CC1310 from Texas Instruments) is the next step to go to an IoT node supporting services for 10 years with a CR2032 coin cell battery (see for the concept: http://www.ti.com/tool/TIDA-00484). You can find the PCB at https://PCBs.io/share/rG9GP. Not tested yet!!!
Do those modules support LoRa modulation? The only references I found mention it supporting a modulation similar to LoRa.
First (after I recieved the PCB’s) I am going to test the power concept of TI. Next step to test the HF. I just read “no LoRa support”, see: http://e2e.ti.com/support/wireless_connectivity/proprietary_sub_1_ghz_simpliciti/f/156/t/611585
Not specifically, but it looks like its a FSK type device which needs signal levels around 5dB to 10dB above noise level to operate, wheras LoRa devices can operate at up to 20dB below noise level, a significant link margin improvement.
The LoRa devices go down to circa 0.2uA in sleep mode so why would you want to use something else ?
If you want to order my design from pcbs.io, maybe you have to wait a few days because there will be an update soon. Improved the antenna connection (@marioz) and ADC6 and ADC7 (analog exclusivily) are not connected to JP3 anymore but PB0 and PB1 (possibility for soft serial).
hi Wijnand
when do you update? There is still the “old” version on PCBs.io
thanks
At.this moment I am in Italie (F1, Monza, Max Verstappen) until friday. I will try to update it the next weekend. Regards…
OK, the update is there (https://PCBs.io/share/46aR0). The update to V2.0: ADC6 and ADC7 (analog exclusivily) are not connected to JP3 anymore but PB0 and PB1 (possibility for soft serial). The HF part has now a switch to SMA or spring antenna and added are GND planes on both sides. If there is interrest I can add an i2c sensor (temp and/or humidity) above JP3. Let me know…
The PCB design with the VT-s02c module from Vincent Tang/China equipped with a CC1310 from Texas Instruments is also updated to V2.0 and tested for basic functions with Code Composer Studio V8. See: https://PCBs.io/share/rG9GP
Hi @Wijnand Do you have any conclussion? Have you tested it?. I do not see dht22 pinout, It has some built-in sensor for temperature and humidity?
@xz81 The second version (V2.0) is not tested yet, I am still waiting for the board, must arrive this week. Both parts (the VT-S02C with the CC1310 and the battery management (booster and power timer/switch) are tested seperately and that works. The combination test is for V2.0. The board is equiped with the MAX30205 (only temperature) but the pinheaders have al the communication pins (SPI, I2C, UART and ADC) for other sensors (as DHT22). There wil be a version V3.0 with PCB antenna and maybe not the VT-S02C ($4) but a normal CC1310 ($???).
