Passing a hex string to a payload decoder in Node-RED
This may help?
And indeed, when using Node-RED already, I’d not use the payload formats in TTN Console anymore.
Aside, note that a LoRaWAN application payload is really an array/buffer/list of bytes, so: values from 0 to 255. Hexadecimal is just one (of the many) human-readable representations of that.
Aside: your decoder does not support negative temperatures. See the post I quoted from above for a fix.
